Determining convergence/divergence?
  • Thread starter Thread starter man0005
The discussion revolves around determining the convergence or divergence of series, specifically focusing on the series involving the expression (9 + cos(n))/n^2 and another series related to (5/n)^n. Participants explore various convergence tests and clarify the implications of the initial value of n in summation notation.
  • Exploratory, Conceptual clarification, Mathematical reasoning, Problem interpretation
  • Participants discuss the application of the squeeze theorem and the comparison test for series convergence. There are questions about the meaning of the initial value of n in the context of series and whether it affects convergence. Additionally, there is exploration of the ratio test and the integral test for different series.
Participants have engaged in clarifying the appropriate tests for convergence and have provided guidance on the application of these tests. There is an ongoing exploration of different series and their convergence properties, with some participants expressing uncertainty about their methods and seeking further clarification.
There are mentions of specific series starting points and the implications of these on convergence, as well as references to textbook answers that may conflict with participants' findings. Some participants are also addressing potential errors in their calculations or assumptions.
man0005
For (9 + cos (n))/ n^2
would this be correct?
since -1 < cos x < 1
then
8/n^2 < (9 + cos (n))/ n^2 < 10/n^2?
So use p-series from there?
Therefore it converges
Am I right?
What exactly are you trying to determine, whether the sequence
$$a_n = \frac{9 + \cos n}{n^2}$$ converges or whether the series
$$\sum_{n=1}^\infty \frac{9 + \cos n}{n^2}$$ converges?
sorry for not clarifying
the series
where n = 1
It looks like you're trying to use the squeeze theorem, but that's for showing a sequence converges. You want to use a test that shows that a series converges. You've correctly deduced that the terms of the series are less than or equal to 10/n2, which is a p-series that converges. Given this info, what test can you use to conclude that the original series converges?
Would it be the comparison test?
Yes, that'll work.
ah thanks heaps!
just one more thing
what exactly is the meaning of the "n" value?
Would my answer be different for n =2 or n = 0?
I assume you're referring to what appears below the summation sign. What's written there tells you the initial value of n. n=0 won't work because you'd be dividing by 0 in the first term of the series. (I fixed the error in my previous post.) You should read up on summation notation if you have further questions.
As far as convergence goes, where the series starts doesn't really matter. Whether a series converges or diverges depends solely on the behavior of the terms as n goes to infinity.
ah i see, that clears it up
thanks again!
What about this one: (5 / n)^n
Would this be a valid method of testing?
1) Ratio test to end up with
(5n^n) / (n+1)^(n+1)
2) Take out 5 / (n + 1) as a factor
3) Left with 5 / (n + 1) * 1 / (n + 1)^n
4) Since the limit of 5 / (n + 1) = 0
Using limit laws, the whole thing must therefore = 0
Since 0 < 1
It converges
This isn't correct. You seem to have dropped the nn that was in the numerator.
Since 0 < 1
It converges
oh yeah
but wouldn't that make it
5 / (n + 1) * n^n / (n + 1)^n
So would my step 4 still be valid?
As long as you can show that ##\displaystyle\lim_{n \to \infty} \frac{n^n}{(n+1)^n}## exists.
hmmm not sure how to do that :S
Any hints?
Or is there an easier test that I should be doing...
Edit: Just tried it and got 1/e
Working out =
lim (n→∞) [ n / ( n + 1 ) ]ⁿ
= lim (n→∞) { 1/ [ ( n + 1 ) / n ] }ⁿ
= lim (n→∞) { 1 / [ 1 + (1/n) ] }ⁿ
= 1 / { lim (n→∞) [ 1 + (1/n) ]ⁿ }
= 1 / e (Using known identity)
That seem okay?
Yup, perfect!
hmm just tried this question from my texbook:
Series of
3 / (3n*(ln (n))^0.5)
where n = 2
Used the integral test and found that it diverges, but answer at the back of the book says it converges. Is the answer wrong? Fairly sure I haven't made any mistakes...but I can post up my working if it's meant to converge
The book's wrong.
Ah cool
Just to confirm the method:
1) Show that related function is positive
2) Show that it is also decreasing via negative gradient
3) Get a definite integral from 2 to infinity or 2 to N
Should end up with limit of 2(ln(N))^0.5 - 2(ln(2))^0.5 with N ---> Infinity
Second is a constant, so can remove it
Now we have lim (n→∞) { 2(ln(N))^0.5}
Which is infinity, hence it diverges
Therefore original series will diverge as well by integral test
Yes, that's fine.
