Determining Form factor from density distribution
2 replies · 2K views
Rayan
Show that the form factor of density distribution $$ \rho (r) $$ is $$F(q^2) $$
$$ \rho (r) = \rho_0 \cdot e^{-\frac{r}{R}} $$
$$F(q^2) = \frac{8\pi \rho_0 R^3}{1 + \frac{q^2R62}{h^2} }$$
So my first thought was that I can just use Fourier trick and integrate:
$$ F(q^2) = \int_V \rho(r) \cdot e^{ i \frac{ \vec{q} \cdot \vec{r} }{h} } d^3r $$
$$ F(q^2) = 2\pi \rho_0 \int_0^{\infty} r^2 \cdot e^\frac{-r}{R} dr \cdot \int_0^{\pi} \sin{\theta} \cdot e^{ -i \frac{q \cdot r \cos(\theta) }{h} } d\theta $$
$$ F(q^2) = 2\pi \rho_0 \frac{-h}{iq} ( \frac{ e^{ i \frac{q \cdot r }{h} } - e^{ -i \frac{q \cdot r }{h} } }{r} ) \int_0^{\infty} r^2 \cdot e^{\frac{-r}{R}} dr $$
$$ F(q^2) = \frac{-4\pi h \rho_0}{q} \int_0^{\infty} \sin(\frac{qr}{h}) e^{\frac{-r}{R}} \cdot r dr $$
But the integral is very complicated, which probably means I missed up somewhere on the way, but I can't really see it! Any tips?
The expression in parentheses is a function of ##r## and should be inside the integral. Instead of combining the two exponentials into a sine function, you might try leaving them as exponential functions. Can you work out the following integral? $$\int_0^{\infty} e^{ i \frac{q \cdot r }{h}}\cdot e^{\frac{-r}{R}} rdr $$
Reply
You're totally right! I managed to solve this integral instead and got the right answer! Thank you so much!!:)
Reply
