Determining Mass of Moment of Inertia for Flywheel in IC Engine
To determine the mass moment of inertia for a flywheel in an internal combustion engine, the desired speed fluctuation must be kept at or below 1.5% at 560 RPM. The mass moment of inertia can be calculated using the relationship between kinetic energy, angular velocity, and the coefficient of fluctuation, as outlined in the referenced textbook. An iterative method may be necessary to solve the equations, particularly if direct integration of the torque curve is impractical. Alternative methods like Simpson's or the Trapezoidal rule can be used for complex torque-displacement functions. Ultimately, the integration approach may be necessary to obtain accurate values from the torque graph.
marquez
i have diagram of the turning moment in flywheel in internal combustion engine , i want to determine the mass of moment of inertia of the flywheel needed to keep speed fluctuation < or equal 1.5% at engine speed 560 rpm ?
http://img534.imageshack.us/img534/1765/57306264.jpg
From my book "Fundamentals of Machine Elements" 2nd Edition by Hamrock, Schmidt, and Jacobsen, the equation for the mass moment of inertia can be calculated from knowledge of the speed fluctuation and kinetic energy. Here is how the authors state it.
"By knowing the desired coefficient of fluctuation for a specific application, obtaining the change in kinetic energy from the integration of the torque curve, and knowing the angular velocity, the mass moment of inertia required can be determined."
Ke = I*w^2*C
where
ke = kinetic energy
I = mass moment of inertia
C = coefficient of fluctuation
w = average omega value (angular velocity)
I = ke / C*w^2
Since the two equations are dependent upon each other you can use an iterative procedure to obtain the two results. I haven't done this myself so I don't know how fast the results will converge or if they will at all. If that doesn't work then use the integration of the torque curve.
Thanks
Matt
Shigley goes into a bit more detail.
C_s=\frac{\omega_2 - \omega_1}{\omega}
\omega = \frac{\omega_2 + \omega_1}{2}
E_2 - E_1 = \frac{I}{2} \left[(\omega_2 - \omega_1)(\omega_2 + \omega_1)\right]
E_2 - E_1 = C_s I \omega^2
from my book also "https://www.amazon.com/dp/019515598X/?tag=pfamazon01-20" in page : 680 : many of the torque - displacement functions encountered in practical engineering situations are so complicated that they must be integrated by approximate methods. like Simpson's or Trapezoidal rule
but i need more directly method or equation to solve that faster than integration
Thanks matt
OK , maybe i use this equations after use integration to get value from graph
Thanks
Posted June 2024 - 15 years after starting this class. I have learned a whole lot. To get to the short course on making your stock car, late model, hobby stock E-mod handle, look at the index below. Read all posts on Roll Center, Jacking effect and Why does car drive straight to the wall when I gas it? Also read You really have two race cars. This will cover 90% of problems you have. Simply put, the car pushes going in and is loose coming out. You do not have enuff downforce on the right...
Thread 'Physics of Stretch: What pressure does a band apply on a cylinder?'
Scenario 1 (figure 1) A continuous loop of elastic material is stretched around two metal bars. The top bar is attached to a load cell that reads force. The lower bar can be moved downwards to stretch the elastic material. The lower bar is moved downwards until the two bars are 1190mm apart, stretching the elastic material. The bars are 5mm thick, so the total internal loop length is 1200mm (1190mm + 5mm + 5mm). At this level of stretch, the load cell reads 45N tensile force. Key numbers...
I'm trying to decide what size and type of galvanized steel I need for 2 cantilever extensions. The cantilever is 5 ft. The space between the two cantilever arms is a 17 ft Gap the center 7 ft of the 17 ft Gap we'll need to Bear approximately 17,000 lb spread evenly from the front of the cantilever to the back of the cantilever over 5 ft. I will put support beams across these cantilever arms to support the load evenly
