Determining nuclear radius by electron diffraction
The equation R = 0.61λ/sin(θ) is derived from the principles of diffraction, specifically related to electron scattering off a nucleus. It relates the radius of the nucleus to the wavelength of the electrons and the angle of diffraction. The discussion references Babinet's principle and the diffraction pattern produced by a circular disk, where the angle θ corresponds to the first minimum in the diffraction pattern. The relationship D = 2R connects the diameter of the nucleus to its radius. Overall, the equation provides a method for estimating nuclear radius using electron diffraction data.
dt19
can anyone explain to me, where does the equation R=\frac{0.61\lambda}{sin\theta} come from when determining the approximate radius of the nucleus by electron scattering?
I think it has something to do with diffraction. Look up "diffraction by a disk".
I just read that it is possible to calculate the diffraction pattern behind a disc by Babinet's principle.
sin(theta) = 1.22*lamda/D, from circular diffraction. D=2R, so R = 0.61*lamda/sin(theta).
