Determining Signal Transmission Speed in a Transmission Line
The discussion centers on how signal transmission speed is determined in a transmission line, exploring factors such as inductance, capacitance, and dielectric properties. Participants examine both theoretical aspects and practical implications, including the effects of different materials used in transmission lines.
  • One participant inquires about the factors determining signal transmission speed, suggesting conductivity may play a role.
  • Another participant presents the formula for speed as u = sqrt(1/LC), indicating that inductance (L) and capacitance (C) per unit length are key factors.
  • It is noted that the speed of propagation is more closely related to the dielectric constant of the insulator rather than the conductivity of the metal, which primarily affects losses.
  • Further contributions emphasize the importance of inductance and capacitance in a 2-conductor transmission line for determining propagation speed.
  • One participant questions whether resistance and leakage conductance also influence wave velocity in lossy transmission lines, acknowledging some uncertainty about their roles.
  • Another participant discusses the types of dielectrics used in coaxial cables and their impact on velocity factors, providing specific percentages related to common materials like polyethylene and Teflon.
  • Two participants clarify that there are two distinct topics: the velocity factor related to electromagnetic radiation speed and pulse propagation related to charge movement, both influenced by distributed L and C.
Participants generally agree on the significance of inductance and capacitance in determining signal transmission speed, but there is some disagreement regarding the influence of resistance and conductance in lossy lines. The discussion remains unresolved on the exact roles of these factors.
Some participants express uncertainty about the contributions of resistance and leakage conductance to wave velocity, indicating a need for further exploration of these aspects.
This discussion may be useful for individuals interested in electrical engineering, telecommunications, or anyone seeking to understand the principles of signal transmission in transmission lines.
americanforest
How is signal transmission speed determined in a transmission line? For example, what determines how long it takes a single pulse to go from one end of a line to the other end. I would assume it depends directly on the conductivity of the material from which the line is made but I'm not sure about that. Can someone refer me to a source which gives me a detailed explanation?
speed u = sqrt(1/LC); L=inductance per unit length, C=capacitance per unit length
The exact relation depends on the transmission line.
However, the speed of propagation is not related conductivity of the metal (the conductivity is only related to the losses in the line) but to the dielectric constant of the dielectric (the insulator); the speed of propagation is roughly [itex]1/\sqrt\epsilon[/itex].
Remember that the wave in a transmission line is not actually traveling in the metal (at high frequencies the skin depth is very small) but in the dielectric.
To tune in with the previous poster: in a 2-conductor transmission line, what determines essentially the propagation speed are two elements:
1) the inductance per unit of length of the conductors
2) the capacitance per unit of length between the conductors.
Can anyone refer me to a book or website with a discussion concerning this subject?
isn't there also the resistance per unit length and possibly a leakage conductance (between the two conductors) per unit length?
well (looking at the wiki page), maybe you're completely right, but i thought that R and G played a role in determining wave velocity in a lossy transmission line. but, it appears (not solving the diff eq myself) that it's just C and L.
maybe start here with the Telegrapher's_equations. the book or books i have on the topic are soooo old (35 years) that i can't recommend since they must certainly be out of print.
hi,, the transmission speed is propably depends on the line capacitance and line inductance,both components are reciprocal to speed.
There are only really three types of dielectric (insulator) used in coax cable. Air where the inner conductor is supported at regular intervals, PE (Polyethylene) or Teflon (PTFE). PE is by far the most common.
The velocity factor for PE is about 66% of the speed of light. PTFE it is about 70%. Some coax cables use foam or semi-air spaced PE and the velocity factor will be higher.
http://www.nr6ca.org/vf.html
Foam or air are used mainly to allow a larger centre conductor to be used for the same impedance in order to reduce loss. Loss per length increases with frequency due to the skin effect. The current travels in a thin skin near the surface of the conductor and the depth of this skin reduces as you go up in frequency.
There are two different topics in discussion here.
1. Velocity factor, the speed of electromagnetic radiation through a medium is dependent on the dielectric constant of the medium, as discussed in posts #3, #8.
2. Pulse propagation per the OP is about the movement of charge; that depends on the circuit characteristics distributed over the transmission line, namely inductance and capacitance, as discussed in the rest of the posts.
Thus, if you would like to know how long it takes a pulse entering a transmission line to reach its final peak amplitude at the other end you need only know the distributed L,C of the line.
Thanks for clarifying this, it was very confusing
  • · Replies 21 ·
  • · Replies 39 ·
10K
