Determining smallest possible diameter of a cable
  • Thread starter Thread starter kaffekjele
    Cable Diameter
4 replies · 2K views
kaffekjele
You have a round steel cable with diameter d and a ultimate strenght of 400Mpa.
There is a force of 8,2KN working along the cable.
What is the smallest possible diameter the cable can have without breaking?
δ= N/A
Area of a circle: πr^2
δ= N/A = N/πr^2
Where N is the force working on the cable and δ is the ultimate strength of the cable.
Not sure about the placement of δ here:
r^2 = N/δπ
I tried working with the formula above by putting 8,2*10^3N/400*10^6Pa*π and taking the square root of the answer in order to find r. I ended up with an answer(for r) of 0,0255 and that seems too small to be correct.
I'm basically wondering about two things:
Am I on the correct path with regards to the formula?
Am I using the units correctly? (Pa vs N)
δ= N/A
δ= N/A = N/πr^2
r^2 = N/δπ
I tried working with the formula above by putting 8,2*10^3N/(400*10^6Pa*π) and taking the square root of the answer in order to find r. I ended up with an answer(for r) of 0,0255 and that seems too small to be correct.
(Use adequate parentheses.)
What are your units for the answer, 0.0255 ?
Is that a diameter or a radius ?
Also check the location of the decimal point in the answer.
My bad, the answer would be for radius, r, so the diameter would be 2*r which would be 0,051.
As for units, if the answer above is correct, the only thing that makes sense is that it's in meters, thereby giving a diameter of 5,1cm. (But, units, exponents etc. is something i really have to work on)
Have you checked the location of the decimal point, as suggested by TSny ?
