Determining stability of min phase system using GM and PM
The discussion clarifies that a minimum phase system is defined as one where both the system and its inverse are causal and stable, which is more restrictive than simply being stable. It emphasizes that gain margin and phase margin are crucial for determining the stability of the open loop transfer function, not the closed loop system. A minimum phase system can still become unstable if the gain margin or phase margin is negative, indicating that the open loop transfer function's gain exceeds stability thresholds. The Nyquist stability theorem is referenced as a method to analyze closed loop stability using the open loop transfer function. Understanding these distinctions is vital for accurately assessing system stability in control theory.
HasuChObe
Alright, there's something I don't understand. The book says that the gain margin and phase margin must be non-negative for a minimum phase system to be stable. But the definition of a minimum phase system is one without right half plane poles or zeroes. Doesn't that inherently make it stable? Looking for a good explanation.
Your definition of minimum phase system is not correct:
"[A] system is said to be minimum-phase if the system and its inverse are causal and stable."
http://en.wikipedia.org/wiki/Minimum_phase
So the definition is more restrictive than just stable. The definition also doesn't care how you get the stability.
Also, I am not 100% sure about this but I think phase margin and gain margin only apply to systems with feedback. However there is nothing in the definition of a minimum phase system that requires feedback (i.e. the system could be an open amplifier).
Okay, maybe not the definition, but one of the properties as a result of what you just said. But that still doesn't answer the question. Even in your definition, it says the system is stable. How is there instability resulting from gain margins and phase margins in my stable system?
I guess I don't understand the question.
Here is what I thought you were asking:
System with such and such gain and phase margin = stable
Minimum phase system = stable
As both systems are stable, what makes them different?
Alright, I figured out what the answer was. But my original question was this.
The book states that, given that a system is minimum phase, if the gain margin or phase margin are negative, the system is unstable. My issue was that a minimum phase system is already stable. Turns out, the book was referring to the open loop transfer function of the system, which makes a lot more sense. If the closed loop transfer function was minimum phase, the system would definitely already be stable. The open loop transfer function being minimum phase does not guarantee stability of the closed loop transfer function.
The stability for a closed loop system can be found using the open loop transfer function with the nyquist stability theorem which is where gain and phase margin come into play.
Negative gain margin? What is that anyway? You mean less than 1?
Gain margin is how much gain (in decibels) you can add to the open loop transfer function of a feedback system before it becomes unstable. Essentially, if the transfer function of the open loop is minimum phase, you want the magnitude of the open loop transfer function to be less than 1 (which, in decibels, results in a negative dB value) when the phase is 180. This criteria relates to the Nyquist stability theorem. So if the gain at 180 degrees phase has a negative dB value, the gain margin would be positive. This indicates how much gain in dB you can add before your system becomes unstable. If the magnitude is greater than 1, and your open loop transfer function is minimum phase, your system is going to be unstable. The gain in dB at 180 degrees will be some positive number which means the gain margin would be a negative value.
