Determining the autocorrelation function
4 replies · 3K views · last reply
L.Richter
Stress described as:
S(t) = a0 + a1X(t) + a2X2(t)
where X(t) is a the random displacement, a Gaussian random process and is stationary.
Determine the autocorrelation function of S(t) (hint: remember a nice formula for the evaluation of high order moments of Gaussian random variables).
Rxx(T) = E[X(t)X(t+T)]
I am unsure of how to approach the problem using the above equation. Please advise. I can do the math I just need to see the setup with the proper functions plugged in.
Maybe you are confused by having the equation be in terms of x when in this case it is in terms of s?
[tex]R_{SS}(\tau)= E\{S(t)S(t+\tau)\}[/tex]
Am I correct in thinking that I have to calculate the product of the mean of S(t) and S(t+T)?
Also since the X(t) is stationary, can I assume that S(t) is also stationary and that the expectation would be S(t)2?
You are correct in that you must calculate the mean of S(t) times S(t + T). You are also correct that S(t) is stationary. You are incorrect, however, in thinking you would compute the expectation of S(t)2. A WSS process will have an autocorrelation that is a function of a time difference. Computing the expectation of S(t)2 would give you the autocorrelation of S evaluated at a time difference of zero. You want a function for all time differences. The time difference is T the way you write it.
Insert the definition of S(t) into that expectation. Distribute the terms on each other. Use the linearity of the expectation operator.
Thank you so much for your help!
This is part 4 of one problem. I still have 2 more complete problems to do! I will keep you in mind for any further help, if that's ok.
