Determining the domain and range of multi-variable function
The discussion revolves around determining the domain and range of the multi-variable function f(x,y) = 1/y^2 - x. Participants are exploring the conditions under which the function is defined and how to approach finding its range, particularly in the context of multi-variable functions.
  • Some participants attempt to identify where the function is undefined, specifically noting that it occurs when y^2 - x = 0. Others express confusion about how to define the range in a multi-variable context, questioning the implications of including both x and y.
Participants are actively discussing the interpretation of the function's expression and its implications for domain and range. There is acknowledgment of the need for clarity in notation, particularly regarding the use of parentheses to avoid misinterpretation. Some guidance has been offered regarding the range, noting that 0 is not included, but further exploration of other potential exclusions is ongoing.
Participants are preparing for an upcoming exam and are seeking detailed understanding, indicating that the discussion is framed within a study context. There is a mention of the need for clarity in defining terms and concepts related to multi-variable functions.
cathal84
f(x,y) = 1/y^2-x
find the domain of f.
Given c ∈ R \ {0} find (x, y) ∈ R 2 such that f(x, y) = c. Finally determine the range of f.
I know that the domain of the function is anywhere that the function is defined.
in the case of this question i can see that the function is going to be undefined where y^2-x =0
since anything over 0 is undefined.
I believe that for the range part of the question it is essentially saying, define the range such that x and y are real numbers but please correct me if I'm wrong.
When i used to be dealing with functions such as f(x) = x+1, in that case i knew that the domain was where the function was defined over the x-axis and i knew that the range was where the function was defined over the y-axis.
But since the domain now is including X and Y i have no idea by what they mean by finding the range.
So if someone could help me define the range of this function and show me the steps to defining the range of any other multi-variable like this one i would greatly appreciate it!
This question is purely for study purposes for exam in start of January so feel free to go into as much detail as you want if you feel it would aid understanding. Thanks again!
cathal84 said:
f(x,y) = 1/y^2-x
You need to write the right side as 1/(y2 - x).
What you wrote means ##\frac 1 {y^2} - x##, which isn't what you meant, based on your work below.
The range is the set of real numbers z such that ##z = \frac 1 {y^2 - x}##. Obviously 0 is not in the range of this function. Are there any other values that aren't in the range?
cathal84 said:
f(x,y) = 1/y^2-x
You wrote
$$f(x,y) = \frac{1}{y^2} - x,$$
at least when we read your expression using standard parsing rules. If you mean something else you need to use parentheses.
If you mean
$$f(x,y) = \frac{1}{y^2-x},$$
then write it in plain text as f(x,y) = 1/(y^2-x).
If you mean
ah yes sorry ill know for next time to put the brackets in thanks for the advice.
I don't see why any other numbers would not be in the range besides 0 but then again I'm just looking at where the function is undefined but that's how you define the domain, so i am not sure, think i am just confusing myself. what exactly am i looking to do differently when defining the range?
