Determining Thermal Coefficient of Binary Solvent Mixture
The discussion focuses on creating silica aerogels through freeze-drying, specifically the need for solvent mixtures with low thermal expansion coefficients to prevent damage to the aerogel matrix during crystallization. The main challenge is determining the thermal expansion coefficient for mixtures of solvents, such as Tert Butanol and Propanol. There is a suggestion to use thermodynamic relations to find the coefficient, particularly dV/dT, although this method may be complex. The impact of the solvents being in solid state on the thermal expansion coefficient is also questioned. Understanding these coefficients is crucial for successful aerogel production.
OptiPessimist
Hello,
Currently, I am working on a science project involving the creation of silica aerogels through the process of freeze-drying. As a result, i need to experiment with mixtures of solvents with low thermal expansion coefficients (so the crystallization of the solvents will not damage the aerogel matrix) However, i have hit a huge impediment.
While it is relatively simple to look up the thermal expansion coefficients for a given solvent,
how would one determine the thermal expansion coefficient for a mixture of solvents? (For example, the thermal expansion coef of a mixture of Tert Butanol and Propanol?)
Would the coefficient be nearly the same if the solvents were in solid state? (For they will be frozen, then sublimated)
Science news on Phys.org
i would suggest finding dV/dT using thermodynamic relations. might get a bit hairy
Can you explain this method a bit more in depth?
Thanks
bump...
I need to calculate the amount of water condensed from a DX cooling coil per hour given the size of the expansion coil (the total condensing surface area), the incoming air temperature, the amount of air flow from the fan, the BTU capacity of the compressor and the incoming air humidity. There are lots of condenser calculators around but they all need the air flow and incoming and outgoing humidity and then give a total volume of condensed water but I need more than that. The size of the...
Thread 'Why work is PdV and not (P+dP)dV in an isothermal process?'
Let's say we have a cylinder of volume V1 with a frictionless movable piston and some gas trapped inside with pressure P1 and temperature T1. On top of the piston lay some small pebbles that add weight and essentially create the pressure P1. Also the system is inside a reservoir of water that keeps its temperature constant at T1. The system is in equilibrium at V1, P1, T1. Now let's say i put another very small pebble on top of the piston (0,00001kg) and after some seconds the system...
I was watching a Khan Academy video on entropy called: Reconciling thermodynamic and state definitions of entropy. So in the video it says: Let's say I have a container. And in that container, I have gas particles and they're bouncing around like gas particles tend to do, creating some pressure on the container of a certain volume. And let's say I have n particles. Now, each of these particles could be in x different states. Now, if each of them can be in x different states, how many total...
