Determining Vector and Parametric Eqns
  • Thread starter Thread starter ttpp1124
    Parametric Vector
To determine the vector and parametric equations for the line passing through points M(4, 5) and N(9, 5), one can choose the direction of the line. The line can be described from M to N or from N to M, as lines do not inherently possess a direction. The choice of direction affects the representation but does not change the line itself. Ultimately, both representations are valid for the given points. Understanding this flexibility is key in vector and parametric equation formulation.
ttpp1124
M(4,5) and N(9,5)
To find the direction vector, is it M-N or N-M?
Not Available
It depends on which direction you want.
The question states "A line passes through the points M(4, 5) and N(9, 5). Determine vector and parametric equations for this
line."
So it's M to N? Meaning M-N?
line."
Does a line have a direction?
No, not always
ttpp1124 said:
No, not always
In this case you get to choose, right? You can choose to describe the line from ##M## to ##N## or from ##N## to ##M##.
Ok, thank you
