Device for Electric Scooter, to get the speed?
The discussion revolves around developing an application to connect to an electric scooter for obtaining speed and engine temperature readings. Participants explore various device options, including sensors and microcontrollers that can interface via Bluetooth Low Energy (BLE).
  • One participant seeks advice on devices to measure speed and engine temperature for an electric scooter, considering BLE connectivity for a mobile application.
  • Another suggests using a microcontroller (uC) board with sensors for easier integration with a phone app.
  • There is a question about whether a small Bluetooth controller could replace a microcontroller for this project.
  • Participants discuss the size constraints of using an Arduino board, with one expressing a preference for a much smaller device that would be less obtrusive on the scooter.
  • Links to various BLE microcontroller resources and products are shared to help the original poster find suitable components.
  • One participant mentions the possibility of using a reed switch for speed measurement, suggesting it could be attached to the wheel with a magnet for speed calculations.
  • Another participant proposes looking into Bluetooth RPM/speed sensors designed for bicycles as a potential solution.
Participants do not reach a consensus on the best approach or specific devices to use, with multiple competing views and suggestions presented throughout the discussion.
Participants express uncertainty regarding the size and practicality of various components, and there are unresolved questions about the best methods for speed and temperature measurement.
Individuals interested in DIY electronics, mobile app development, or those looking to enhance electric scooters with additional monitoring capabilities may find this discussion beneficial.
smallville2010
I want to do an application that can connect to my Electric scooter (the kind you stand on)
and can get a speed and engine temperature readings,
i'm looking into a device
i can attach to the wheel
or a temperature gauge
i can attach to the engine
and get a reading from both of them
something i can connect using BLE with an application that i'll write using native android and native ios.
it's a project, that is only the start.
do you know where to start ?
i mean do you know of something of that sort like a temperature, and engine reading gadgets that work with BLE ?
Welcome to the PF.
Have you done any projects with Arduino boards or similar microcontrollers (uCs)? It's probably easiest to use a uC board on the scooter with sensors, and a BLE interface to send the information to your phone app...
would it be better then to use a normal small Bluetooth controller, without arduino ?
do you know any sensors or uC board links you can give me to get started ?
I did a google search on BLS Microcontroller for Phone Apps, and got lots of good hits. Maybe look through these links and videos to start to get ideas for ways you could pursue this... :smile:
https://www.google.com/search?q=ble...one+apps&ie=utf-8&oe=utf-8&client=firefox-b-1
i think most of them refer to arduino,
and that means i have to actually put an around 8cm on 8cm box (or there is a smaller arduino ?) on my electric scooter,
i wanted to put something very very very small that you cannot even feel it,
maybe even something like a mini ble speed checker that can connec tot he phone
something like this
https://www.amazon.com/dp/B07BPRDS8D/?tag=pfamazon01-20
or this
https://www.amazon.com/dp/B00L9XNFPY/?tag=pfamazon01-20
what do you think ?
is it a good direction ? or not what I'm looking for
Is this small enough?
BoB
Here is a maybe for the speedometer: https://www.amazon.com/gp/product/B00NW882KM/?tag=pfamazon01-20
The ad doesn't say what the sensor is, you will probably need to download the manual from the supplier or manufacturer.
Both of those you linked to attach to the pedals of a bike and tells you how fast your are pedaling.
That sounds like a cool project! I'd start by creating a simple circuit that can measure speed/temperature then connect it all up to your phone app using Bluetooth.
I'm guessing you're going to want to use an Arduino for this project, because it will just make things simpler.
And as rebelli1 mentioned they come in quite small sizes too!
For calculating the speed you could use a reed switch, which is simply a switch that responds to a magnet. Here's a reed switch example image:
If you place a reed switch on the frame of the wheel, then attach magnet on the wheel. The Arduino would then need to calculate the time interval between each spin, you would also need to specify a few other variables such as tire thickness and wheel circumference then you should be able to calculate the speed. Here's an example of a reed switch for calculating speed:
Here is a link that goes into more detail, and also provides some code for the speed calculation that you could use. In their project they display the information on an LCD display, but in your case you could send the data via Bluetooth to your phone app.
https://www.instructables.com/id/Arduino-Bike-Speedometer/
And finally to measure temperature you would need to use a sensor, using one of these is fairly straightforward just connect it up to an Arduino and add some code to read the temperature and send the data across to your phone app. Image of a temperature sensor:
nt.solarbotics.com%2Fproducts%2Fphotos%2Fe618e1f23a7b7860f3f1b7fc5a8779a9%2Flrg%2F35040-img_0674.jpg
If your scooter is electric you may want to place it near the motor, or maybe one on the battery too! Those parts get the most warm during operation. Here's a useful link about connecting the temperature sensor to an Arduino:
https://www.instructables.com/id/ARDUINO-TEMPERATURE-SENSOR-LM35/
Hope this helps! :wink:
  • nt.solarbotics.com%2Fproducts%2Fphotos%2Fe618e1f23a7b7860f3f1b7fc5a8779a9%2Flrg%2F35040-img_0674.jpg
Might be able to buy a Bluetooth rpm/speed sensor intended for bicycles?
  • · Replies 26 ·
  • · Replies 25 ·
  • · Replies 31 ·
