exmarine said:
I think I read somewhere that Feynman once said that if we could measure the earth’s diameter, it would be maybe an inch short of what we would expect from the circumference and Euclid. Is that correct?
No. The proper diameter (the diameter we would measure with rulers) is
longer than the circumference divided by ##\pi##. A brief calculation follows.
Looking back at the thread A. T. linked to, I realized that, while Jonathan Scott's formula for the potential (of a uniform density sphere) is correct, his assumption that the potential is what you need to calculate the proper diameter is wrong. What you need is the metric coefficient ##g_{rr}##; the potential is ##g_{tt}## .
Fortunately, the metric coefficient ##g_{rr}## is actually simpler to work with, particularly if we are willing to make a rough estimate. This metric coefficient is given by
g_{rr} = \frac{1}{1 - \frac{2 G m(r)}{c^2 r}}
where ##m(r)## is the "mass inside radius ##r## ". The square root of this value gives the ratio of proper distance to coordinate distance at radius ##r##. Since we always have ##g_{rr} \ge 1## for ##r \ge 0## , we can already see that proper distance will always be at least as large as coordinate distance, and will be strictly larger for any ##r## greater than zero and less than infinity. But the order of magnitude of my estimate should be correct.
Since ##m(r)## is zero at ##r = 0## , and is just ##M## , the total mass of the Earth, at ##r = r_e##, we can do a quick rough estimate by just averaging the two values of ##\sqrt{g_{rr}}##. One value is just 1; the other value, plugging in numbers, comes out to about ##1 + 2 \times 10^{-9}##. So averaging tells us that the proper diameter of the Earth is larger than the coordinate diameter (i.e., the circumference divided by ##\pi## ) by about ##10^{-9}## times the coordinate diameter, or about 1 centimeter. Note that this is a rough estimate; a more accurate calculation would have to first obtain the function ##m(r)## by integrating the density from ##r = 0## outward, and then evaluate the integral ##\int_0^{r_e} \sqrt{g_{rr}} dr## using the function ##m(r)## that was obtained.
