Did I get it right by coincidence?
  • Thread starter Thread starter flyingpig
    coincidence
The discussion revolves around a physics problem involving two parallel rails and sliding metal rods in a magnetic field. The user attempts to calculate the current in a resistor but encounters confusion regarding the variables used, particularly the distinction between the distance between the rails and the length of the rods. There is a significant error in the user's calculations, resulting in a current value that is 1000 times greater than the book's solution. The conversation highlights the importance of correctly identifying the parameters in the problem, specifically the effective length of the rods in relation to the magnetic field. Ultimately, the user expresses frustration with understanding electromagnetism concepts.
flyingpig
OKay, PF again erased my hard 30mins work of LaTeX and wouldn't let me backspace. So I apologize if I miss any crucial detail
Two parallel rails with negligible resistance are 10.0 cm apart and are connected by a 5.00 resistor. The circuit also contains two metal rods having resistances of R = 10.0Ω and 15.0 Ω sliding along the rails. The rods are pulled away from the resistor at constant speeds 4.00 m/s and 2.00m/s, respectively. A uniform magnetic field of magnitude 0.0100 T is applied perpendicular to the plane of the rails. Determine the magnitude and direction of the current in the 5.00 Ωresistor
http://img219.imageshack.us/img219/7499/p3131alt.th.gif
Uploaded with ImageShack.us
So I did my loop
Left Loop -I_1 R_1 - Blv_1 - I_1 R_3 + I_2 R_3 = 0
Right Loop -Blv_2 - I_2 R_2 - I_2 R_3 + I_1 R_3 = 0
Add some numbers
Left Loop -15I_1 + 5_2 = 4Bl
Right Loop 5I_1 - 20I_2 = 2Bl
\begin{bmatrix}<br /> -15 &amp; 5&amp; 4\\ <br /> 5&amp;-20 &amp; 2<br /> \end{bmatrix}
\begin{bmatrix}<br /> 1 &amp; 0&amp; \frac{-18}{55}\\ <br /> 0&amp; 1 &amp; \frac{-10}{55}<br /> \end{bmatrix}
So I1 = 18/55A and I2 = 10/55A
So the current down the middle resistor must be 8/55A which is 0.145A
Here is the book solution
http://img853.imageshack.us/img853/9262/81989521.th.gif
I didn't even use the 10cm...
TeX fixed
You didn't use the B field either AND your answer is 1000 times what the books solution is.
0.145A=145 mA. not μA.
Also, you didn't mention the direction of the induced EMF.
I didn't mention or the question? Probably me, the book is better than me lol. Oh yeah the B-field too. But how did they get 145μA?
Sammy, what is your time zone? In case I need help and I move during the Summer lol
(Central zone. I often stay up way too late. fp, what's your Time Zone?)
B=0.010 T, ℓ (or d) = 0.10 meters, so Bℓ = 0.0010 = 1/1000, and your answer is 1000 times the correct answer.
I live in Canada right now, so Pacific? It's like 12:23pm right now.
Also I thought l is the length of the rod and the "l" (they have d) is the distance travelled
They plug in 0.100m for d. d is the distance between the rails.
But that isn't right
\varepsilon = Blx
x is the distance traveled and l is the length of the rod. The "d" in the problem is said to be the distance between them, but in Blv, the v is dx/dt which already took care of the distance travelled, but l is still untouched
You have Blv\,,\ (and you threw away the Bl\,).
The posted solution has B\,d\,v\,. Their d corresponds to your ℓ.
It's very clearly the case.
BTW: Your equation, \varepsilon = Blx is in error.
\mathcal{E}=-\,\frac{d\Phi}{dt}=-B\ell\frac{dx}{dt}=-B\ell v
I didn't throw it away! I just forgot to use B = 0.001T!
I know it corresponds to my "l", but the "l" given is wrong, the 10cm is the distance between the wires, l is supposed to be the length of the rod according to my textbook.
For <br /> \varepsilon = Blx<br /> I thought we only put the minus sign when we want the direction as in this https://www.physicsforums.com/showthread.php?t=486781?
Sigh, I think I have to realize that I am just not cut out for physics, I don't understand why E&M is so difficult for me lol.
The minus sign isn't the problem.
No, but the d and l is, I don't understand why they think the distance between the rods is the length of the rod themselves!?
In the problem as you posted it, no variable is assigned to the length of the rods. (BTW: to get technical, it's the distance between the rails that's important. Any portion of the rod extending past the rails doesn't carry current.)
It's clear that your solution uses l as the effective length of each rod. It's equally clear (to me at least) that the book solution uses d as the effective length of each rod.
Doesn't that mean the rods' distance is 10.0cm apart? Not the length of the each rod
The two rails are stationary & are 10.0 cm apart. The rods sit on the rails, so each rod is 10.0 cm long. This is the d in the book solution.
Yup
How did you deduct that? Of course without the solution from the book?
I suppose there should have been a figure showing the rods to be perpendicular to the rails, thus the portion of each rod that carries current is equal to the distance from one rail to the other.
