Dielectric Constant of Food in microwave
The discussion focuses on the dielectric constant of food items, specifically marshmallows, eggs, and cheese, when heated in a microwave. The experiment yielded dielectric constant values of 0.97 for marshmallows, 2.2 for eggs, and 0.87 for cheese, which contradict established physics principles stating that dielectric constants cannot be less than 1. A participant clarified that using the standard microwave frequency of 2.45 GHz, the expected dielectric constants should be approximately 0.89 for marshmallows, 0.59 for eggs, and 1.5 for cheese. The conversation highlights the complexity of measuring dielectric properties in food due to the influence of the microwave chamber's geometry and air, rather than the food itself.
  • Understanding of dielectric constants and their significance in materials science.
  • Familiarity with microwave oven physics, particularly the frequency of 2.45 GHz.
  • Knowledge of electromagnetic field behavior in confined spaces.
  • Basic principles of wave measurement and analysis.
  • Research the relationship between dielectric constants and food materials.
  • Explore the effects of microwave chamber geometry on electromagnetic wave propagation.
  • Learn about the ideal resonant cavity approximation in microwave applications.
  • Investigate alternative methods for measuring dielectric properties in non-gaseous materials.
This discussion is beneficial for physicists, food scientists, and engineers interested in the dielectric properties of food and the implications of microwave heating on material behavior.
nagrom777
I made the experiment up myself so my errors may be a result of this, but I heated up marshmallows, eggs and cheese in the microwave and measured the distance between the hotspots in order to get the wavelengths. For the marshmallows I got 0.13cm, for the eggs I got 0.16cm and for the cheese I got 0.10cm.
However when I plugged these into the equation to get dielectric constant:
c=(λ)(f)√ε
I got marshmallows=0.97, eggs=2.2, and cheese=0.87
and I read somewhere that dielectric constants can't be less than 1.
We don't cover dielectric constant in my physics class, and my teacher doesn't know too much about it in relation to food
I don't know if it was a flaw in my experiment, if the heat of the microwave or fact that it was food instead of a gas, or maybe that dielectric constants in food follow different guidelines,
but if anyone has any idea about this and could just explain where I went wrong I would appreciate it so much!
Thanks in advance!
I think you mean 13cm not 0.13cm etc.
I'm not sure how you got your values, but using the standard microwave oven frequency f = 2.45 GHz, along with your formula, I get the relative dielectric constants to be:
Marshmallow: 0.89; Egg: 0.59; Cheese: 1.5
I would expect these values to be much higher (as in, something on the order of 10 or 100) if they are indeed the dielectric constants of these materials.
I could be wrong, but I suspect the problem is that the distance between hotspots is not actually the wavelength of light within the food. Rather, it has more to do with the air in the microwave chamber and the geometry of the chamber. So basically, instead of measuring the wavelength of light inside the food you're heating, you're getting a very rough measurement of the wavelength of light inside the chamber (i.e. the wavelength of light in air).
That's just my guess though, can anyone confirm/deny?
Google found this article which suggests there is a lot more to it. It questions the whole issue of measuring the speed of light or wavelength using a microwave oven..
http://www.wensh.net/archive.php/topic/1527.html
VI. Conclusions
E&M field in microwave oven is analyzed. It is not a simple plain wave or a 1D standing wave. Thus the method of measuring speed of light by measuring 6cm apart hot spots does not make sense. Instead, the method by measuring “components” of wavelength is more reasonable. However, it is valid only in the ideal resonant cavity approximation. In a real microwave oven, all sorts of perturbation can fail this method.
  • · Replies 33 ·
  • · Replies 0 ·
  • · Replies 19 ·
  • · Replies 25 ·
