Dielectric surface in the field of an oscillating dipole
The discussion focuses on computing the reflected and transmitted electric fields from an oscillating electric dipole interacting with a dielectric surface, a topic not readily addressed in standard electromagnetics textbooks. Participants suggest using Fourier decomposition to represent the dipole's fields as a superposition of plane waves, which simplifies the analysis. Texts by Stratton, Kong, and Chew are recommended as potential resources, with a preference for Kong's and Chew's approaches due to their more manageable methodologies. The Sommerfeld integral and Weyl Identity are highlighted as relevant concepts in understanding the relationship between point sources and their Fourier transforms. Overall, the conversation emphasizes the need for specialized resources to tackle this complex problem.
gaganaut
We have the equations available for computing the reflected and transmitted electric fields in the case when a plane wave is incident on a dielectric surface.
Now what I wish to do is compute similar reflected and transmitted components of the electric field due to an oscillating electric dipole. The equation for this type of electric field is available and is not of a plane wave nature. Now if we have a dielectric surface in this field, how do we go about computing the reflected and transmitted components?
I have referred to quite a few Electromagnetics textbooks but none seems to have a ready to use solution for this. Please direct me to a source that talks about this, if there is one.
Appreciate all the help.
Thanks
Thanks
The easiest thing to do might be to use Fourier decomposition to represent the fields of the oscillating dipole as a superpostion of plane waves. After all, the whole point of studying plane waves is that any EM wave can be decomposed as a superpostion of them.
Thanks Gabbagabbahey. That sounds interesting and really promising, now that I think about it. I will look into it and post my experience with it here. Thanks for the clue though, this might be it.
This kind of problem is dealt with in textbooks by Stratton, Kong, and Chew. I prefer Kong's textbook or Chew's because I find Stratton's use of Hertzian potentials to be more unwieldy than Kong's and Chew's use of point source potentials. I am sure that Kong's text also has this, but Chew's also contains a discussion about the Sommerfeld integral and Weyl Identity which relate a point source to it's Fourier transform in terms of cylindrical waves and plane waves or just plane waves.
Thank you Born2bwire. This is very helpful. I will now try and see if my library holds these books. I really appreciate.
I was using the Smith chart to determine the input impedance of a transmission line that has a reflection from the load. One can do this if one knows the characteristic impedance Zo, the degree of mismatch of the load ZL and the length of the transmission line in wavelengths. However, my question is: Consider the input impedance of a wave which appears back at the source after reflection from the load and has traveled for some fraction of a wavelength. The impedance of this wave as it...
