What is the Differential Equation for Velocity with Air Resistance in Free-Fall?
  • Thread starter Thread starter heyjude619
    Diff eq Velocity
The discussion focuses on deriving the differential equation for an object in free-fall experiencing air resistance proportional to the square of its velocity. The equation is established as dv/dt = -32.2 + 0.0095v^2, where 32.2 ft/s² represents gravitational acceleration. Participants clarify that the gravitational force should be included in the total force acting on the object. The correct formulation of the ordinary differential equation for integration is confirmed as dv/dt = 32.20 - kv². The conversation emphasizes understanding the forces at play in free-fall scenarios.
heyjude619
An object in free-fall has an acceleration (which is the rate of change in velocity with respect to time) of 32.2 feet per second2 downward plus air resistance. The air resistance is proportional to the velocity squared. If the initial velocity is 0 feet per second and the proportionality constant is .0095, write and solve a differential equation that would result the function describing the velocity at any given time.
Ordinary diff eq?
dv/dt = -32.2 + .0095v^2
Tried to solve for v
Can you separate variables in your ODE ?
Ohh, yes, thank you! It's been awhile since I've done a diff eq... But, can I ask your opinion? Since it says the object is free falling, we should assuming it is still being acted upon by the force of gravity, right? So, is the acceleration given, 32.2 ft/s^2, the acceleration of the total force? Like this:
F(total)=F(air)-F(falling)=kv^2-mg
F(total)=ma=m*32.2
Or should I subsitute the 32.2 in for the gravity?
Thanks!
No, the 32.2 ft/s^2 is the value of the gravitational acceleration g.
\frac{dv}{dt} = 32.20 - k v^2
is the ODE to be integrated.
Question: A clock's minute hand has length 4 and its hour hand has length 3. What is the distance between the tips at the moment when it is increasing most rapidly?(Putnam Exam Question) Answer: Making assumption that both the hands moves at constant angular velocities, the answer is ## \sqrt{7} .## But don't you think this assumption is somewhat doubtful and wrong?
