Difference between a snug tight and a fully tensioned bolt?
  • Thread starter Thread starter chris_usyd
    Bolt Difference
The discussion clarifies the distinction between a snug tight bolt and a fully tensioned bolt. A snug tight bolt is achieved by turning the bolt until it stops, resulting in minimal gap and no rattling, typically indicated by a low-to-nil setting on a torque wrench. In contrast, a fully tensioned bolt is tightened to a specific engineering specification using a torque wrench, ensuring optimal performance. Proper pretensioning is essential for fatigue resistance under cyclic loading, highlighting the importance of adhering to specified torque settings.
  • Understanding of torque wrench settings
  • Knowledge of bolt tensioning principles
  • Familiarity with engineering specifications for fasteners
  • Basic concepts of mechanical fatigue and cyclic loading
  • Research "Torque wrench calibration techniques"
  • Study "Engineering specifications for bolt tensioning"
  • Explore "Effects of pretensioning on mechanical fatigue"
  • Learn about "Fastener failure modes and prevention"
Mechanical engineers, construction professionals, and anyone involved in assembly or maintenance of bolted joints seeking to enhance their understanding of bolt tensioning and its implications for structural integrity.
chris_usyd
anyone knows the difference between a snug tight and a fully tensioned bolt?
thanks in advance:thumbs:
Turn the bolt until it stops, there is little or no visible gap and does not rattle when you shake it - a low-to-nil setting on a torque wrench for eg or just "finger tight". This is "snug tight".
The bolt will turn further than that - when it is turned to a non-zero setting on the torque wrench, it is a tensioned bolt. When it is tensioned to the enginerring spec, then it is "fully tensioned". Above or below the spec then it is over or under tensioned respectively.
http://www.skf.com/files/880426.pdf
thanks very much, simon.
it helps.
The more you pretension a bolt, assuming you are doing it correcting (e.x. using washers), the better that bolt can resist fatigue due to cyclic or repeated loading. So, there are sometimes fundamental reasons for pretensioning bolts to a certain spec, aside from making sure the bolt doesn't come loose..
... which is the most likely way someone may be puzzled about this :)
... and the link in post #2, reappearing in #3, goes into detail - yep.
And people think that "doing up bolts" is simple ;)
  • · Replies 18 ·
