Difference between Centroid and Centre of Pressue
The Centre of Pressure (CP) and Centroid are distinct concepts in fluid mechanics, particularly when analyzing submerged surfaces. The Centroid is the geometric center of a shape, while the Centre of Pressure is the point where the resultant pressure force acts, which can differ due to pressure gradients. For submerged surfaces at angles, the pressure is not uniform, leading to a shift in the Centre of Pressure from the Centroid, as explained by Pascal's Law (P = ρgh). This distinction is crucial for accurate calculations in hydrostatics.
  • Understanding of fluid mechanics principles
  • Familiarity with Pascal's Law
  • Knowledge of pressure distribution in submerged surfaces
  • Basic geometry related to Centroid calculations
  • Study the application of Pascal's Law in fluid statics
  • Explore pressure distribution on inclined surfaces in fluid mechanics
  • Learn about hydrostatic forces on submerged surfaces
  • Investigate the calculation methods for Centre of Pressure
Students and professionals in engineering, particularly those focused on fluid mechanics, civil engineering, and naval architecture, will benefit from this discussion.
Yam
What is the difference between the Centre of Pressure and Centroid
My understanding is that the centre of pressure acts on a centroid. So, how come they can be on different positions for a submerged surface?
If pressure is applied evenly to a flat surface, then the center of pressure is the centroid. If a submerged surface is at an angle, then the pressure is not constant across the surface.
Even if the submerged surface is perfectly vertical, the centroid and the c.p. don't coincide because of the pressure gradient due to Pascal's Law where P = ρgh.
Likely RUber meant at an angle to the horizontal, which would include 90 degrees.
11K
  • · Replies 17 ·
