Difference between continuity and uniform continuity
12 replies · 6K views
Yunjia
I noticed that uniform continuity is defined regardless of the choice of the value of independent variable, reflecting a function's property on an interval. However, if on a continuous interval, the function is continuous on every point. It seems that the function on that interval must be uniformly continuous. Is this correct? Is there a counterexample for the statement?
What you said is almost true. If, on a closed, bounded interval, a function is continuous at every point, then the function is uniformly continuous on that interval.
Counterexample on a non-closed interval: ##f(x) = 1/x## on the interval ##(0,1)##.
Counterexample on a closed but unbounded interval: ##f(x) = x^2## on the interval ##[0,\infty)##.
Even more general: If a function is continuous at every point in a compact set, it is uniformly continuous on that set.
The proof is simple: Let the compact set be K and take an ε>0. Since the function is continuous at every point x in the set, there is a δx for every x∈K such that |f(w)-f(x)|<ε for every w in <x-δx, x+δx>. Let Ox=<x-δx, x+δx>, then K is contained in [itex]\bigcup_{x\in K}O_{x}[/itex]. Since K is compact, it is contained in the union of a finite number of the Ox, say [itex]\bigcup_{n=1}^{N}O_{n}[/itex]. Take δ to be the minimum of the δn and |f(w)-f(x)|<ε whenever |w-x|<δ.
And here's the proof that a closed, bounded interval is compact, so you can apply Svein's proof.
Let ##[a,b]## be a closed, bounded interval, and let ##\mathcal{U}## be any collection of open sets which covers ##[a,b]##. Let ##S## be the set of all ##x \in [a,b]## such that ##[a,x]## can be covered by finitely many of the sets in ##\mathcal{U}##. Clearly ##a \in S##. This means that ##S## is nonempty and is bounded above (by ##b##), so it has a supremum, call it ##c##. Since ##c \in [a,b]##, it is contained in some ##U_c \in \mathcal{U}##, hence there is some interval ##(c - \epsilon, c + \epsilon)## contained in ##U_c##. Since only finitely many sets from ##\mathcal{U}## are needed to cover ##[a,c - \epsilon/2]##, those sets along with ##U_c## form a finite cover of ##[a,c+\epsilon/2]##. This shows that ##c \in S## and moreover, that ##c## cannot be less than ##b##. Therefore ##c=b##, so all of ##[a,b]## can be covered by finitely many sets in ##\mathcal{U}##.
Excellent! And, of course, since one closed and bounded interval is compact, the union of a finite number of closed and bounded intervals is again compact.
I don't think this will work if ##w## and ##x## are not contained in the same ##O_n##. I think you need to take ##O_x = (x - \delta_x/2, x + \delta_x/2)## and ##\delta## to be ##\min\{\delta_n/2\}## in order to ensure that ##|w-x| < \delta## implies ##|f(w) - f(x)| < \epsilon##.
jbunniii said:
I don't think this will work if ww and xx are not contained in the same OnO_n. I think you need to take Ox=(xδx/2,x+δx/2)O_x = (x - \delta_x/2, x + \delta_x/2) and δ\delta to be min{δn/2}\min\{\delta_n/2\} in order to ensure that |wx|<δ|w-x| < \delta implies |f(w)−f(x)|<ϵ|f(w) - f(x)| < \epsilon.
Possibly. I need to think about that. The crux of the matter is that there is a finite number of intervals that cover K, which means that the minimum of the (finite number of) δ's exist and is greater than 0.
Here is the fundamental difference between "continuous" and "uniformly continuous":
A function is said to be continuous at a point, x= a, if and only if, given any [itex]\epsilon> 0[/itex] there exist [itex]\delta> 0[/itex] such that if [itex]|x- a|< \delta[/itex] then [itex]|f(x)- f(a)|<\epsilon[/itex].
A function is said to be continuous on a set, A, if and only if, given any [itex]\epsilon> 0[/itex] there exist [itex]\delta> 0[/itex] such that if [itex]|x- a|< \delta[/itex] then [itex]|f(x)- f(a)|<\epsilon[/itex] for all a in set A.
That is, a function is uniformly continuous on a set A if and only if it is continuous at every point in A and, given [itex]\epsilon> 0[/itex] the same [itex]\delta[/itex] can be used for ever point in A.
Agree. I was sloppy and overlooked the simple fact that that the length of the interval Ox is 2⋅δx.
The defition of uniformly continuous is perplexing for me. Is it possible for you to illustrate it with a proof about a function which is not uniformly continuous but continuous on a set so that I can compare the two? Thank you.
OK. Take the function [itex]f(x)=\frac{1}{x}[/itex] on the open interval <0, 1>. It is continuous (and even differentiable) on that interval, but not uniformly continuous.
After using pencil an paper for a bit, I came to the conclusion that I should have used ε/2 and δ/2. But - I recall a proof in "Complex analysis in several variables" that ended up in "... less than 10000ε, which is small when ε is small".
First note an important point about "uniform continuity" and "continuity" you may have overlooked: we define "continuous" at a single point and then say that a function is "continuous on set A" if and only if it is continuous at every point on A. We define "uniformly continuous" only on a set, not at a single points of a set.
A function is uniformly continuous on any closed set on which it is continuous and so on any set contained in a closed set on which it is continuous.
To give an example of a function that is continuous but not uniformly continuous, we need to look at f(x)= 1/x on the set (0, 1).
To show that it is continuous on (0, 1), let a be a point in (0, 1) and look at [itex]|f(x)- f(a)|= |1/x- 1/a|= |a/ax- x/ax|= |(a- x)/ax|= |x- a|/ax< \epsilon[/itex].
We need to find a number, [itex]\delta> 0[/itex] such that if [itex]|x- a|< \delta[/itex], then [itex]|f(x)- f(a)|> \epsilon[/itex]. We already have [itex]|x- a| ax\epsilon[/itex] so we need an upper bound on ax. If we start by requiring that [itex]\delta< a/2[/itex] then [itex]|x- a|< \delta< a/2[/itex] so that [itex]-a/2< x- a< a/2[itex]or [itex]a/2< x< 3a/2[/itex] so an upper bound on ax is [itex]3a^2/2[/itex]. If [itex]|x- a|< a/2[/itex] <b>and</b> [itex]|x- a|< 3a/2[/itex] then [itex]|f(x)- f(a)|< |x- a|/ax< |x- a|/(3a^2/2)= 2|x- a|/3a^2[/itex] which will be less than [itex]\epsilon[/itex] as long as [itex]|x- a|< 3a^2\epsilon/2[/itex]<br /> <br /> So we can take [itex]\delta[/itex] to be the <b>smaller</b> of [itex]a/2[/itex] and [itex]3a^2/\epsilon[/itex]. Therefore, 1/x is continuous at any point a in (0, 1) so continuous on (0, 1).<br /> <br /> Now the point is that this [itex]\delta[/itex] depends on a. It is a decreasing function of a and will go to 0 as a goes to 0. That's fine for "<i>continuity</i>" but for <i>uniform continuity</i> we must be able to use the <b>same</b> [itex]\delta> 0[/itex] for a given [itex]\epsilon[/itex] no matter what the "a" is and we cannot do that. If the problem were to prove uniform continuity on the set [p, 1), which is contained in the closed set [p, 1], we could use, for any a in that set, the [itex]\delta[/itex] that we get for a= p, the smallest x value in the set. But with (0, 1), the smallest [itex]\delta[/itex] is 0 which we <b>cannot</b> use since we must have [itex]\delta> 0[/itex].[/itex][/itex]
