Difference between coupling and constrain equations in ansys
The discussion revolves around the differences between coupling and constraint equations in ANSYS, particularly focusing on their applications in finite element analysis. Participants explore technical details, examples, and specific use cases related to static analysis, mass transfer, and element selection in ANSYS.
  • Homework-related
  • Some participants suggest that coupling equations operate on a nodal basis while constraint equations operate on an elemental basis.
  • One participant describes their preference for using coupling commands like CP, CPINT, and CPCYC for specific scenarios, emphasizing the importance of matched nodes and tolerances.
  • Another participant seeks clarification on how to best transfer mass in a chassis static analysis, expressing confusion between using CPs and RBEs.
  • There is a query regarding the appropriate value for gravitational acceleration in a G load analysis, with participants discussing unit conversions and the implications of using different units.
  • A participant mentions using a point mass element connected via CERIG for modal analysis and asks how to verify mass transfer in ANSYS.
  • One participant raises an issue with using shell 91 elements due to a radius/thickness ratio violation, while noting that shell 181 does not present this problem.
Participants express differing views on the best methods for mass transfer and element selection in ANSYS, indicating that no consensus exists on these topics. Additionally, there is uncertainty regarding the correct value for gravitational acceleration based on unit systems.
Participants mention specific commands and their applications, but there are unresolved assumptions regarding the definitions of terms like CP and RBE, as well as the implications of using different element types in ANSYS.
Individuals engaged in finite element analysis using ANSYS, particularly those interested in coupling and constraint equations, mass transfer methods, and element selection for static and modal analyses.
anoopsrikanth
What is the difference between coupling and constrain equations in ansys
IIRC one is on a nodal basis, while the other is on an element basis.
Thanks
Can u explain be with a example or in detail and wt does iirc means
IIRC == If I Remember Correctly
As far as an example, I typically preferred to do coupling on a nodal basis, via CP, CPINT, or CPCYC commands.
CP is used when typically when you're manually joining together two groups of nodes that may not necessarily be coincident.
CPINT is used when you have two adjacent surfaces that you'd like to connect. Often times I would use these instead of contact regions. Contact regions make the problem nonlinear and increase solution time drastically. Aside from that, they are picky and can often ruin a solution if not defined well.
So, as an example, let's say that you're doing a 2D axisymmetric analysis of two tubes, one which fits inside the other. You could take the nodes at the interface and couple them via CPINT only in the UX direction (radial). This would allow the parts to slip both tangentially (if doing 3D) and axially.
CPCYC is cyclic coupling. I've typically used it when doing a 3D sector analysis. The other option is the CYCLIC command which like coupling commands, increases solution drastically. If you were doing a slice of a part, you would select the outer slice nodes, issue the CPCYC command in all directions (ensuring you were in the correct coordinate system).
All of the CP commands assume that you either have matched nodes, or at least close. There is typically a tolerance on the commands, but aside from that they assume matched nodes. In fact, if you increase the tolerance too much, you'll get nodes being coupled to more than 1 node on the adjacent side, and the solution will bomb.
CE commands are very similar except they operate on an elemental basis, meaning they doing require matched nodes. Because of this, however, I find that they don't quite work as well.
thanks for the info.
i am doing a chassie static analysis how can i best transfer the mass of a structure sitting on the chassie. i know that creat a mass element and it can transfer the load but connect it throug CP or RBEs confused pls help me
I would use CPs. I know of RBEs, know that they have their uses, but haven't found myself using them very often. Create a mass and CP it to the applicable position(s) on the chassie...do you mean chassis?
I am doing a G load analysis,Can any suggest the correct value to GRAVITY
Model Units in MM, Density in Tonne/mm3, Youngs Modulus in MPa
I am confused weather to take 9810 or 9.810
Please Suggest
What are the units of acceleration? What unit are you using for length? What about time? You're using metric, it should be pretty straightforward.
Be lucky you doing have to worry about gc.
If Length in mm g is mm/s2 is the value of g will be 9810 mm/s2 or 9.810 mm/s2 confused little bit please help me out.
Try solving the following equation using [kg] and [m/s²] to get [N]:
F = m.a
Now try again combining [kg] or [tonne] and [m/s²] or [mm/s²].
Which mass and acceleration units can be combined to give the same numerical result as [kg] and [m/s²] ?
Which combination returns consistent units ?
Thanks Boss I got your answer
Hi Boss
I am doing modal analysis free-free on a structure on which a huge mass is sitting i have created a point mass element and connected using CERIG to transfer mass. Does the analysis will consider the huge mass and give the results or there is any other option.
Also how to cross check in ANSYS weather the mass is transferred to the structure or not.
Please help me
Check your output file. It lists total mass of each defined element type.
i got it thanks
hi,
i am doing static analysis of compressor housing. i am considering shell 91 element for generating FE model as it has the option of taking thickness in one direction, wereas other elements take thickness from center and divide it equally either sides.
but my problem is that shell 91 is giving a message
ELEMENT 1 HAS A RADIUS/THICKNESS RATION OF 0.1085(MIN RADIUS OF CURVATURE OF 0.32 AND A MAX THICKNESS OF 3). THIS VOILATES THE ASSUMPTION OF A SHELL ELEMENT.
whenusing shell 181 the problem is solving without any errors.
please help me in solving the problem using shell 91 or any other element having option of taking thickness in one direction
