Difference between digital and discrete signal
Digital signals are a subset of discrete signals, characterized by having finite values, often represented as binary (0 and 1). While digital signals can be continuous in time, such as PWM signals, they can also be discrete, existing only at specific time intervals. Discrete signals are defined at particular sampling rates, converting continuous analog signals into discrete forms. The sampling process creates a discrete analog signal, which is then transformed into binary digital values. Understanding these distinctions is crucial for applications in signal processing and communications.
pvvijaykumar
what is difference discrete and digital signal
Welcome to PF;
That is a reasonable question - what have you done to discover the answer?
Have you, for instance, looked up the definitions of the two terms online?
A digital signal is a special case of a discrete signal.
A digital signal can be discrete or continuous. A digital signal can only have a set of finite values. If the digital signal is *binary*, it can only have 2 values, 0 or 1. A PWM signal is an example of a continuous signal (NOT discrete), and binary digital having just 2 values. A discrete signal is one that is defined only at specific time intervals. If an continuous analog or digital signal is sampled at some rate, the sample set is a discrete signal. If the sample rate is 1.0 kHz, then there is a sample value every 1.0 milliseconds. This can be digital or analog. If the signal is analog (continuous), it can have any value, i.e. the vertical axis value is not restricted. But the horizontal time axis has values defined only at the 1.0 msec sample points.
Summary: a digital signal can only have discrete values, for binary digital those values are 0 and 1. A digital signal can be continuous in time, such as a PWM signal. Or it can be discrete, where the data exists at specific values of time. An analog signal sampled by an A/D sample and hold is converted to a discrete analog signal. Then the A/D converts it to binary digital, i.e. 0 and 1 values only.
I hope I helped. A great text is the signals and systems book by B.P. Lathi.
Claude
Thread 'I thought it was only Amazon that sold unsafe junk'
I grabbed an under cabinet LED light today at a big box store. Nothing special. 18 inches in length and made to plug several lights together. Here is a pic of the power cord: The drawing on the box led me to believe that it would accept a standard IEC cord which surprised me. But it's a variation of it. I didn't try it, but I would assume you could plug a standard IEC cord into this and have a double male cord AKA suicide cord. And to boot, it's likely going to reverse the hot and...
