Difference between direct coupled and transformer coupled?
The discussion centers around the differences between direct coupling and transformer coupling in mechanical configurations, particularly in the context of audio amplifiers and other applications. Participants explore the implications of each coupling method, including their uses and historical context.
  • One participant asks about the difference between direct coupled and transformer coupled systems, specifying mechanical configurations with turns ratios.
  • Another participant clarifies that direct coupling means no transformer is involved, prompting a request for more context regarding the question.
  • Several participants inquire about the specific applications of transformer and direct coupling, suggesting areas such as audio amplifiers or RF systems.
  • A participant notes that transformer coupling can enhance intrinsic safety in environments where isolation is critical, citing examples from military ships.
  • Another participant discusses how the availability and cost of components have influenced amplifier design, highlighting that transformer coupling was historically used to maximize gain but is less common now due to the affordability of transistors.
  • It is mentioned that early audio amplifiers utilized transformers for speaker matching, but modern designs often do not require them due to advancements in amplifier technology.
Participants express varying perspectives on the applications and historical context of direct and transformer coupling, indicating that multiple competing views remain without a clear consensus on the best practices or preferences.
The discussion does not resolve the specific conditions under which each coupling method is preferred, nor does it clarify the assumptions related to their applications in different fields.
rickeystuart
what is the difference between direct coupled and transformer coupled?(mechanical configurations with the required turns ratios of 1:25 direct coupled and 1:1.79 transformer coupled)
Direct coupled means no transformer (and hence no turns ratio). What is the context of your question?
Welcome to the PF, BTW.
Yes.. I think you need to explain a bit more?
thx. when do we use transformer coupling/direct coupling??
For what though?
Do you mean for audio amplifiers or RF or something else??
Hi,
You often have transformer couplings when you want to add an element of intrinsic safety to an environment. Intrinsic safety means all your supplies are effectively isolated via the transformers, a set-up often found in warship ammunition magazines or flight decks (where fuel is present). Two of the ships I served on were ‘intrinsic safe’, mainly because they were stores ships that carried fuel, ammo and dry stores. It didn’t matter so much with the dry stores, but it was a big deal in the mags and around the flight spaces.
For ref, the ships were the RFA Fort Victoria and George.
Hope this helps,
Utwig
If you mean coupling between stages within a chain of amplifiers then the availablity and cost of components has changed the way amplifiers are designed.
Transformer coupling can maximise gain by correctly matching the output impedance from one stage to the input impedance of the next. In decades gone by where expensive and power hungry valves (tubes) were used and in the early days of expensive transistors you wanted to keep the valve or transistor count down. And eqiuipment was bulky so having relatively large transformers didn't matter.
Now, transistors are so cheap that you can use hundreds, thousands and even millions (within integrated circuits) for less than the cost of only 5 or 6 transistors in the past so gain is easy to achieve. It is items like transformers which are now relatively expensive. And if you are using integrated circuits internal stage coupling has to be direct. And of course items are very small these days.. Whole radios, MP3 players can fit within the size of single small transformer.
Early audio output amplifiers used transformer for matching to speakers. They have been designed out with the use of complementary pair NPN-PNP Class B push-pull amplifiers.
  • · Replies 27 ·
  • · Replies 47 ·
9K
  • · Replies 36 ·
13K
