Difference between T-flip flop and clocked SR latch
  • Thread starter Thread starter Bipolarity
    Difference Sr
The primary difference between a T flip-flop and a clocked SR latch lies in their functionality and state change behavior. The T flip-flop toggles its output state when the input is high during a clock pulse, while the clocked SR latch sets or resets its output based on the S and R inputs, changing state only when the clock is high. Additionally, a latch can change state whenever the clock is high, whereas a flip-flop changes state only on the clock edge. The design of a flip-flop typically involves a Master-Slave configuration to ensure state changes occur at the clock edge.
  • Understanding of digital logic design
  • Familiarity with flip-flops and latches
  • Knowledge of clock signals in digital circuits
  • Basic concepts of edge-triggered versus level-triggered devices
  • Research "Master-Slave flip-flop design" for deeper insights into flip-flop architecture
  • Explore "clocked SR latch functionality" to understand its operational characteristics
  • Study "edge-triggered vs level-triggered circuits" to differentiate between latch and flip-flop behavior
  • Examine "T flip-flop applications" to see practical uses in digital systems
Digital circuit designers, electronics engineers, students studying digital logic, and anyone interested in understanding the differences between flip-flops and latches in digital systems.
Bipolarity
Precisely what is the difference between the (clocked) T flip flop and clocked SR latch? I have looked at the logic diagrams for both, but am wondering about functionality differences between the two. How do they differ in their functional use?
All help is appreciated. Thanks!
BiP
They have different functions. The output of a flip-flop is flipped if the input is 1 when it's clocked (i.e. if the output is 0, the next output will be 1 and vice verse). If the input is 0 then the output of the T flop doesn't change. The SR works differently. If S is set the output is 1, if R is set the output is 0 and if neither is set the output doesn't change.
OK thans, so better question:
What's the difference between an SR latch and a clocked SR latch?
BiP
When it's clocked it can only change state when the clock is high. When the clock is low it can't change.
Your next question should be: what's the difference between a latch and a flip-flop (since you're using them interchangeably).
A latch can change state whenever the clock is high.
A flip-flop only changes state on a clock edge (either rising or falling, depending on how it's built)
Thanks!
How does the design of a latch differ from that of a flip flop? It seems for a latch, each input need merely be ANDED with a system clock, which when active allows the latch to change states.
But it seems designing a flip flop would not be so easy, since you want the output to change only on the edge of a clock cycle.
BiP
There are several ways. The simplest way is called the "Master Slave" structure where you have a latch driven by clock in series with a latch driven by the inverted clock. Check out the wikipedia page for "flip flop" for more information.
  • · Replies 34 ·
  • · Replies 28 ·
31K
