Janiceleong26
- 276
- 4
What is the difference between viscuous force and drag force? Are they the same?
Yes. The OP should Google "form drag" and see what comes up.boneh3ad said:Drag comes from a number of sources. The viscous force on a surface is one of those components of drag.
Oh I see...but what really, is the difference between them? They seem to be same.. I usually see the word "drag" used when in air, whereas the word "viscous" used in liquidboneh3ad said:Drag comes from a number of sources. The viscous force on a surface is one of those components of drag.
Viscous is used for both liquids and gases. Form drag is the part of the drag force that comes in when the body converts "dynamic pressure/kinetic energy" of the fluid flowing by to static pressure at its leading bluff edge.Janiceleong26 said:Oh I see...but what really, is the difference between them? They seem to be same.. I usually see the word "drag" used when in air, whereas the word "viscous" used in liquid
sophiecentaur said:I can't find a specific mention of the term Turbulence here and it becomes a factor in drag once the laminar flow breaks up ( at speed) it's a more everyday term than Vortices. Viscous drag is there all the time- even at low speed. Delaying turbulence allows higher speeds with same engine power.
sophiecentaur said:I don't know that we are talking about the same thing but turbulence 'extracts' energy from a moving object. That corresponds to work done and, hence a drag force. Energy is needed to accelerate the fluid and that energy is not returned.
Is there a difference in terminology between us?
sophiecentaur said:Hmm. So you are saying that turbulence ( which is the random formation of vortices?) does not absorb energy?
Should I abandon the use of the description of liquid flow in terms of laminar flow ( low velocity) and turbulent flow (velocity above a threshold value)?
Perhaps I am misunderstand what you seem to be saying.
Oh I see.. Thanks!boneh3ad said:The term "drag" means the force exerted on a body in motion through a fluid that opposes the motion. There are a number of sources of drag, one of which is the action of viscosity near the surface. There are other sources, though, such as the pressure difference from the front of the object to the back or shock waves or wing vortices on a plane. These all make up drag. Viscous drag is simply a part of that.
sophiecentaur said:My elementary Fluid Dynamics is obviously not good enough! Surprise surprise.
The non- monotonic relationship for supersonic flight was a revelation but I guess an object that's short and at high speed can produce odd effects on wave formation by front and back sections.
Intuition really sucks in this field.
