Differential Calculus Problems
The discussion revolves around various problems in differential calculus, specifically focusing on differentiation techniques and the application of rules such as the Quotient Rule and Chain Rule. Participants are addressing multiple differentiation tasks involving trigonometric, exponential, and implicit functions.
  • Mixed
  • Participants discuss their attempts to differentiate functions using the Quotient Rule and Chain Rule, with some expressing confusion over the application of these rules. Questions arise regarding the correctness of their derivatives and the simplification of expressions.
Some participants have provided feedback on each other's attempts, suggesting areas for simplification and clarification of derivative calculations. There is an ongoing exploration of different interpretations of the problems, with no clear consensus reached on the correct approaches.
Participants note issues with automated homework checkers and syntax errors in their submissions, indicating potential constraints in how they present their answers. There is also mention of the need to convert expressions into different forms for clarity.
RedBarchetta
Any help is greatly appreciated! :smile:
1.Differentiate.
http://www.webassign.net/www16/symImages/8/a/e5af282af9dd30006849e16c0b489b.gif
2.Find the derivative of the function.
http://www.webassign.net/www16/symImages/c/8/fd38a158e810bff80a28202fbceb37.gif
3.Consider the following.
http://www.webassign.net/www16/symImages/8/a/68e64f2907886f5478f5c03714da01.gif
(a) Find y ' by implicit differentiation.
(b) Solve the equation explicitly for y and differentiate to get y ' in terms of x.
4.Differentiate.
http://www.webassign.net/www16/symImages/1/a/d96706921943b5f83c856dd9fda12e.gif
5.Differentiate
http://www.webassign.net/www16/symImages/d/d/cc0e49fd81af528239a0b21a0ac5e9.gif
1.On this one I started with the Quotient Rule.
y=sinx/1+cosx
y'=cosx(1+cosx)+(sinx)^2/(1+cosx)^2
y'=cosx+(cosx)^2+(sinx)^2/(1+cosx)^2
I type this in:
(cos(x)+cos^2(x)+sin^2(x))/(1+cos^2(x))
It says: "Check the syntax of your response." I've tried putting them like(cos(x))^2 and (cos^2(x)).
2.I tried this one with the chain rule.
I converted it:
s(t)=(t^3+3/t^3-3)^1/4
Now the derivative of the inside is what gets me.
s'(t)=1/4(t^3+3/t^3-3)^-3/4*(inside)
The inside derivative ends up equaling zero. I'm stumped. I used the quotient rule. Heres my attempt of the inside derivative=
3t^2(t^3-3)-(t^3+3)3t^2/(t^3-3)^2
The numerator equals zero, so that times the first part is zero, leaving me with zero. I tried zero but it was wrong.
3.Alright, differentiate with respect to x right? I started by converting the radicals.
x^1/2+y^1/2=6
Derivative:
1/2x^(-1/2)+1/2y^(-1/2)y'=6
6 is a constant and equals zero, so I moved the x term over, then divided by 1/2y to get y' by it self:
(-.5x^(.5))/(.5y^(-.5))
Wrong. I didnt attempt the second part yet.
4. The derivative(so I've read) of e^x, is simply e^x. I converted the radical. Then applied the product rule.
1/2x^(-1/2)*e^x+x^(1/2)*e^x
Wrong. I think I might have not applied the chain rule to the last term. so If you take the derivative of e^x, it should be e^x? But that shouldn't matter because its still e^x. Right?
5. I took the 2nd power and applied to the the entire term.
(1-u/1+u)^2
Then used chain rule.
2(1-u/1+u)*(inside derivative)
inside=
-1(1+u)-(1-u)*1/(1+u)^2
-1-u-1+u/(1+u)^2
-2/(1+u)^2
final answer:
2(1-u/1+u)*(-2/(1+u)^2)
Still wrong. I'm not sure. This is what I typed: 2((1-u)/(1+u))*(-2)/(1+u)^2
y=sinx/1+cosx
I type this in:
This looks correct, but you should simplify it: use the fact that sin^2x+cos^2x=1. You should then get an expression that you can simplify further by factorising the denominator.
I converted it:
The numerator of the "inside" derivative does not equal zero: 3t^2(t^3-3)-(t^3+3)3t^2=-9t^2-9t^2=-18t^2
x^1/2+y^1/2=6
Derivative:
You've got \frac{1}{2\sqrt{x}}+\frac{1}{2\sqrt{y}}y'=0 Try to make y' the subject of the formula again-- you're algebra went wrong somewhere.
Wrong.
Why's this wrong? Looks fine to me!
(1-u/1+u)^2
inside=
-1-u-1+u/(1+u)^2
-2/(1+u)^2
final answer:
That's not correct since \frac{1-u^2}{1+u^2}\neq\left(\frac{1-u}{1+u}\right)^2.
You should just be able to use the quotient rule on the original expression.
I hate automated "homework checkers"! What you have for 4 is correct. But since the original problem was given in terms of \sqrt{x}, not x1/2, it would be better to write your answer in that form: What you have is the same as ((1/2)x-1/2+ x1/2)ex. If you factor out a (1/2)x-1/2, that is the same as (1/2)x-1/2(1+ 2x)ex which can be written
\frac{1+ 2x}{2\sqrt{x}}e^x
On number 1 I got to this:
(cos(x))/(cos^2(x)+2cos(x))
Still says check your syntax. :confused:
I'm still stumped on number 2 and number 5.
Any help is appreciated.
Thanks!
1.(1+cos(x))^2 \neq 1+cos^2x2.\frac{(t^3+3)^\frac{1}{4}}{(t^3-3)^\frac{1}{4}}
Take it slow, apply the chain rule and the quotient rule.
3. Again, take it slow and apply the chain rule and the quotient rule. Make sure to be careful with your work.
  • · Replies 21 ·
