Differential equation asymptotes
5 replies · 11K views · last reply
lpbug
Hi guys, I just have a very broad and general question.
Today in math class I was asked to solve the horizontal asymptote of a differential equation, and this had me stumped.
Later on, the teacher gave me the following two examples:
dy/dx=x-2
and
dy/dx=y-2
The solution to the first equation for a horizontal asymptote is DNE
The solution to the second is 2
Now, I'm just wondering... How would one know that this is true without solving for the original equation? I mean, this doesn't seem intuitive at all to me. Why is it that when X is what makes the differential equation 0 there is no asymptote and when Y makes the equation 0 there is?
Thanks for all the help.
If you have a horizontal asymptote then as x approaches infinity, dy/dx has to approach zero, right?
but isn't it not enough information just to assume that whenever dy/dx=0 when the y value is making the dy/dx 0? I mean, I see where you're coming from with as x approaches negative infinity or infinity dy/dx has to approach 0 but I don't understand how you can just tell from the equation that a dy/dx involving a y will DEFINITELY have a horizontal asymptote. Is it because all forms of differential equation involving y will have a solution like e^something?
Also, the reason for dy/dx being zero if y is a certain number implying a horizontal asymptote is simple: If when y is a certain number, then dy/dx is zero, then the graph is going to be flat at that point. This means that y won't change as x changes, but since y doesn't change, then dy/dx is going to stay zero. Hence, horizontal asymptote.
aha! I think i got it, so if the slope of dy/dx is 0, either the change in y (dy) must equal 0 OR the change in x (dx) must be infinity? and if the y isn't changing, then the slope will not change after it theoretically reaches 0, because dy/dx is dependent on y itself?
Well, you can definitely say that the first equation doesn't have an asymptote. In the second equation there is at least a possible y value for a horizontal asymptote. One way to look at it is if y>2 then the function y is increasing. If y<2 it's decreasing. Imagine what must happen as x->-infinity.
