Differential Equation by Separation of Variables
The differential equation y' + cos(x)y = cos(x) is solved using separation of variables. The initial attempt leads to the expression -ln|1-y| = sin(x) + C, which is later corrected to account for the constant C. The discussion clarifies that e^(sin(x) + C) can be expressed as e^(sin(x))e^C, allowing for simplification. Ultimately, the solution is refined to y = C/e^(sin(x)) + 1, confirming the correctness of the approach. The final expression is accepted as a valid solution to the differential equation.
TranscendArcu
Solve the differential equation: y' + cos(x)y = cos(x)
y' = cos(x)(1 -y)
\frac{dy}{1-y} = cos(x) dx
\frac{1}{1-y} = e^{sin(x)} + C
1-y = \frac{1}{e^{sin(x)} + C}
y = \frac{-1}{e^{sin(x)} + C} + 1
Have I done this correctly?
No. e^(sin(x)+C) isn't the same as e^sin(x)+C.
So I know e^{sin(x) + C} = e^{sin(x)}e^C. But since e^C is just a constant, can't I just compress it into the constant C?
Yes, but that makes it C*e^(sin(x)), doesn't it?
so I should write,
\frac{1}{1-y} = e^{sin(x)}C
1-y = \frac{1}{e^{sin(x)}C}, and C is totally arbitrary so write,
y = \frac{C}{e^{sin(x)}} + 1
TranscendArcu said:
so I should write,
I think that works.
Question: A clock's minute hand has length 4 and its hour hand has length 3. What is the distance between the tips at the moment when it is increasing most rapidly?(Putnam Exam Question) Answer: Making assumption that both the hands moves at constant angular velocities, the answer is ## \sqrt{7} .## But don't you think this assumption is somewhat doubtful and wrong?
  • · Replies 18 ·
  • · Replies 40 ·
  • · Replies 21 ·
