Differential Equation - Hermite's Equation
The discussion revolves around finding the general solution to the first-order differential equation y' + 2ty = 0. There is a mention of Hermite's equation, which raises questions about the nature of the problem being discussed.
  • Participants discuss the form of the differential equation and whether it is a first or second-order equation. Some express uncertainty about the connection to Hermite's equation and the prescribed methods for solving it, including series solutions.
The conversation is ongoing, with participants questioning the initial problem statement and exploring different interpretations. Some have offered potential methods for solving the equation, while others are clarifying the nature of the equation itself.
There is confusion regarding whether the equation is a first-order or second-order differential equation, which affects the approach to finding the solution. Additionally, participants are considering if there are specific methods they are required to use, such as series solutions.
cse63146
Find the general solution of y' + 2ty = 0
so I know y = [tex]\Sigma^{\infty}_{n=0} a_n t^n[/tex] and y' =[tex]\Sigma^{\infty}_{n=1} n a_n t^{n-1}[/tex]
not sure what to do next.
http://www.sosmath.com/diffeq/series/series06/series06.html"
Is that first line a typo? Should it be y'' (two primes, second derivative)? I'm guessing it is because the link shows a second order DE.
If it is a single prime, then you could do a simple integration to get the answer, unless you have been told to use a series solution.
It's y' + 2ty = 0. Makes the problem a bit easier.
Yah wait a minute, what does that equation have to do with Hermite's equation? Are you SURE it isn't a second order differential equation?
Do you have a prescribed method (like series?)
If not, it is very simple
Devide the Eq by y and you get
y´/y = -2t
Integrate
ln(y) = -t2
y=exp(-t2) + C
that is the general solution
It might not be (even though its in the same section). But I wanted to try and solve that before I move on to the second order version.
