Differential equation using partial fractions
To solve the differential equation 1/P dP/dt = b + aP using partial fractions, first rewrite it as dP/(P(b + aP)) = dt. The left side can be decomposed into partial fractions, expressed as 1/(P(b + aP)) = A/P + B/(b + aP). To find the constants A and B, multiply both sides by P(b + aP) and solve the resulting equation by substituting convenient values for P. After determining A and B, integrate both sides to obtain P in terms of t. This method effectively utilizes partial fractions to simplify the integration process.
Shelby
I need to integrate this differential equation using partial fractions to obtain an equation for P in terms of t; P(t):
1/P dP/dt = b + aP
So far, this is what I have:
ln /P/ = bP + aP^2/2 +c
Where do I go from here, would I take e from each side and then what would I do? and am I doing this right?
Please help me
Multiply both sides by P?
No sense in doing that, since he still needs to bring the P-terms over to the left hand side.
Bring the P-terms from the RHS to the LHS, then separate variables :
\frac{1}{P(aP+b)}dP = dt
Separate the left hand side using partial fractions (write it as \frac{k_1}{P} + \frac{k_2}{aP+b}, then find the values of k1 and k2 quickly with the "Heaviside cover-up" shortcut, for example) and integrate both sides to solve.
1/P dP/dt = b + aP
No. You can't just integrate both sides with respect to P: there is not "dP" on the right side. You can rewrite the equation as
\frac{dP}{P(b+aP)}= dt
and integrate- the left side with respect to P, the right side with respect to t.
As Curious3141 said, you "partial fractions" to integrate the right side.
Please help me
partial fractions
can you point me in the right direction, with all of these variables I keep getting confused?
What more "pointing" do you want! Use partial fractions to integrate
\frac{dP}{P(b+ aP}
Can you do the "partial fractions" decomposition? You want to find A and B so that
\frac{1}{P(b+aP)}= \frac{A}{P}+ \frac{B}{b+ aP}
Multiply both sides of that by P(b+aP) to get
1= A(b+aP)+ BP
and solve for A and B. (Hint: let P= 0 and P= -b/a)
Question: A clock's minute hand has length 4 and its hour hand has length 3. What is the distance between the tips at the moment when it is increasing most rapidly?(Putnam Exam Question) Answer: Making assumption that both the hands moves at constant angular velocities, the answer is ## \sqrt{7} .## But don't you think this assumption is somewhat doubtful and wrong?
  • · Replies 16 ·
