Differential equation with power series method
4 replies · 2K views
Schfra
I need to solve the DE
y’ = x^2y
using the power series method
y = sum(0->inf)Cnx^n
y’ = sum(1->inf)nCnx^(n-1)
I plug in the previous two equations into the DE. What is the general procedure for these problems after that?
I believe I can bring the x^2 into the summation to get
sum(1->inf)nCnx^(n-1) - sum(0->inf)Cnx^(n+2) = 0
I’m not sure what to do after this.
Now you need to solve for the coefficient of ##x^n## for each value of ##n##. So for example ##2c_2 - c_{-1} = 0##. It looks to me like you need to extend your series to include values of ##n## less than 0. Otherwise, all of your coefficients will be zero.
Can you explain what you mean by this and why I have to do this? I did get 0 for my coefficients while attempting to solve earlier.
There are a couple of tricks here. First, assume that ##nc_n - c_{n-3} = 0## for all ##n \in \mathbb Z##. You end up with a recursion. Actually you end of with three recursions. For two of them you easily compute a limit and dispense with them. The other one gives you ##0c_0 - c_{-3} = 0##. What does that imply ##c_{-3n}##? About ##c_0##?
I disagree. The solution to the differential equation has a smooth behaviour around ##x = 0## so expanding it in a Maclaurin series should be perfectly fine.
Also note that you have no ##c_{-1}## so clearly ##c_2 = 0## (which agrees with the exact solution).
