Differential Equations - Hermite Polynomials
The discussion revolves around a problem set related to differential equations and Hermite polynomials, specifically focusing on the solutions of the Schrödinger equations. The original poster expresses confusion about how to approach the problems, which involve showing relationships between certain functions and their derivatives.
  • Participants suggest starting with basic derivative calculations and recognizing patterns in the derivatives of the function V0(x). There are discussions about the application of the Binomial Theorem and the nature of operator powers in the context of the problems. Some participants also question the interpretation of operator notation and its application to functions.
The discussion is active, with participants providing hints and guidance on how to approach the problems. There is acknowledgment of the original poster's realization about overthinking the problem, indicating a shift towards a more productive direction. However, there is no explicit consensus on a single approach or solution.
Participants note that the problems may not require deep knowledge of differential equations or Hermite polynomials, but rather a solid understanding of basic calculus and operator manipulation. There is also mention of the problems being presented in a way that may not align with textbook material.
mathmannn
Here is the entire problem set, but (obviously) you don't have to do it all, if you could just give me a few hints on where to even start, because I am completely lost.
Recall that we found the solutions of the Schrödinger equations
[itex](x^2 - \partial_x ^2) V_n(x) = (2n+1) V_n(x) \quad \quad n = 0,1,2[/itex]
[itex]V_0 (x) = e^{\frac{x^2}{2}} \quad \quad V_n (x) = (x - \partial x)^n V_0(x)[/itex]
1. Show that for each [itex]n[/itex] there is a polynomial [itex]P_n[/itex] such that [itex]V_n(x)=P_n(x)V_0(x)[/itex]
2. Show that for any smooth function [itex]v(x)[/itex]
[itex](x - \partial_x) v(x) = -e^{\frac{x^2}{2}} \frac{d}{dx} \left ( e^{\frac{-x^2}{2}} v(x) \right )[/itex]
During class we went over the commutator of [itex][B,C][/itex] and a lot its it's identities.
Also [itex](x^2 + \partial_x ^2) V_n = (2n+1) V_n \rightarrow V_n := (A^*)V_0 \neq 0[/itex]
I have no idea where to even start on this. None of this is in the book and our professor said that each of the problems can be solved using a few "tricks" and then after that they aren't that hard.
I think the problem set is really not that "deep" in the sense that you need to have a very good unserstanding of differential equations, Hermite Polynomials or anything else. You just need to know how to do derivatives. Take a good look at rules of differential calculus. Compute the first derivative of V0(x). What do you get? Compute the second derivative. Do you see a pattern? You just need to have a real good look at what you are doing. You could also start with exercise 2 since it's more general and then do exercise 1 after that, using the result of ex. 2.
You could start at 2:
[tex](x-\partial x)^2 V_0(x)=\left(x^2-2x\partial x+\partial^2 x\right) V_0(x)[/tex]
Keep in mind that powers of operators are higher-order operators and not operators raised to a power right.
How about 3? Then use the Binomial Theorem for n.
For (2), can't you just use the chain-rule and work through that and show that? Remember when you have expressions like:
[tex](x+\partial x) f(x)[/tex]
that means the operator [itex](x+\partial x)[/itex] operating on the function x. You know that right? Same dif with the first one raised to higher powers
Thank you all very much! I got it, I was just thinking too much into the problem!
Think I'm wrong on that. Rathers it's the operator [itex](x-\partial x)[/itex] operating on the operator [itex](x-\partial x)[/itex] so:
[tex](x-\partial x)^2=(x-\partial x)(x-\partial x)=x^2-x\partial x-\partial x (x)+\partial x \partial x[/tex]
[tex]=x^2-x\partial x-1+\partial^2 x[/tex]
and it's operating on the function f(x), not x as I stated above.
Still gives the polynomial though.
