[Differential Geometry] Matrix of Differential Equations in SO(3)
The discussion centers on proving that the solution to the differential equation $$\dot{Q}(s) = A(s)Q(s)$$ with initial condition $$Q(0) = Q_0$$ remains in the special orthogonal group $$SO(3)$$ for all $$s$$, given that $$A(s)$$ is antisymmetric. The proof involves showing that $$Q^TQ$$ is constant and equal to the identity matrix $$I_{33}$$, and that the determinant of $$Q$$ remains 1 for all $$s$$, leveraging properties of determinants and continuity. The conclusion confirms that $$Q(s) \in SO(3)$$ for all $$s$$.
  • Understanding of differential equations, specifically matrix differential equations.
  • Familiarity with the properties of the special orthogonal group $$SO(3)$$.
  • Knowledge of antisymmetric matrices and their implications in linear algebra.
  • Basic understanding of determinants and the Intermediate Value Theorem.
  • Study the properties of antisymmetric matrices in depth.
  • Learn about the structure and applications of the special orthogonal group $$SO(3)$$.
  • Explore the implications of the Intermediate Value Theorem in continuous functions.
  • Investigate matrix calculus, particularly differentiation of matrix products.
Mathematicians, physicists, and engineers working with rotational dynamics, as well as students studying differential equations and linear algebra.
mef51
Suppose that ##s \to A(s) \subset \mathbb{M}_{33}(\mathbb{R})## is smooth and that ##A(s)## is antisymmetric for all ##s##. If ##Q_0 \in SO(3)##, show that the unique solution (which you may assume exists) to
$$\dot{Q}(s) = A(s)Q(s), \quad Q(0) = Q_0$$
satisfies ##Q(s) \in SO(3)## for all ##s##.
For ##Q \in \mathbb{M}_{33}(\mathbb{R})##, if:
  • ##Q^TQ = I, \quad Q \in O(3)##
  • additionally, if ##det(Q) = 1, \quad Q \in SO(3)##
  • Note: ##Q^TQ = QQ^T## for ##Q \in SO(3)##
For ##A \in \mathbb{M}_{33}(\mathbb{R})##,
  • ##A## is antisymmetric if ##A^T = -A##
Since I only know that ##Q_0## is in ##SO(3)##, I suspect that ##\dot{Q}(s)## must be 0. In that case, since the derivative is zero, ##Q(s)## must be constant and ##Q(s)=Q_0## for all ##s##. So I try to prove that ##A(s)Q(s)## is zero.
Based on a hint someone gave me I'll start by taking the derivative of ##{Q_0}^TQ_0 = I##:
({Q_0}^TQ_0)' = I' \\
\dot{Q_0}^TQ_0 + {Q_0}^T\dot{Q_0} = 0_{33} \\
{Q_0}^T\dot{Q_0} = - \dot{Q_0}^TQ_0 \\
Q_0{Q_0}^T\dot{Q_0} = - Q_0\dot{Q_0}^TQ_0 \\
Now I plug in that expression for ##\dot{Q_0}## in the differential equation..
- Q_0\dot{Q_0}^T Q_0 = A_0Q_0 = -{A_0}^T Q_0
I'm not really sure what this gives me though. I'm also not confident that you can even use the product rule like that. It certainly isn't true for matrices in general.
Any help or pokes in the right direction are appreciated!
mef
I made a mistake in my attempt:
Since ##Q_0## is constant, taking the derivative of ##Q_0## is just 0. Should perhaps take the derivative of ##A(s)Q(s)## instead
Alright let's take the derivative of ##Q^TQ##. If this ends up being zero, then ##Q^TQ## is constant and could be equal to the identity ##I_{33}##. This would prove one of the properties we want ##Q## to have to be in ##SO(3)##. We need to use ##\dot{Q} = AQ## and ##A^T=-A##
(Q^TQ)' = \dot{Q^T}Q + Q^T\dot{Q} \\
\qquad = \dot{Q^T}Q + Q^TAQ \\
\qquad = (AQ)^TQ + Q^TAQ \\
\qquad = Q^TA^TQ + Q^TAQ \\
\qquad = -Q^TAQ + Q^TAQ \\
\qquad = 0\\
So ##Q^TQ## is constant. Can we just say ##Q^TQ = I_{33}## which is constant?
Since ##Q^TQ## is constant ##\forall s##,
##Q^TQ = {Q_0}^T Q_0 = I_{33}## since ##Q_0## is in ##SO(3)##. Ok.
I now need to show that ##det(Q) = 1 \quad \forall s##, knowing that ##det(Q_0) = 1##
I know that ##det(Q^TQ) = det(I_{33}) = 1##
So using properties of determinants
##1 = det(Q^TQ) = det(Q^T)det(Q) = (det(Q)) ^2##
This gives me ##det(Q) = \pm 1## but how can I discard the -1 solution??
Okokok.
Since ##Q(s)## is differentiable, it must be continuous. ##det(Q)## must also be continuous.
Since ##det(Q_0) = 1##, if ##det(Q)## were ever -1, then by the Intermediate Value Theorem there should be an ##s## such that ##det(Q(s)) = 0 ## (or any other value between 1 and -1).
But since ##det(Q)## can only be either 1 or -1, ##det(Q)## can never be -1 without violating the IVT. So we must have that ##det(Q) = 1## for all ##s##.
That in combination with the other posts should prove that ##Q \in SO(3) \quad \forall s##.
##\square##
mef51 said:
Okokok.
##\square##
Yes, I think you pretty much have it. Good job!
  • · Replies 60 ·
9K
