Differential OP AMP Circuit Question
3 replies · 1K views
joey5981
Find Vin/Vout
Vout = Rf/R1(Vb-Va) ?
I think the answer is the first one.
Answer choices:
Vin/Vout = -2, Rin = 100
Vin/Vout = -2, Rin = 200
Vin/Vout = -2.5, Rin = 100
Vin/Vout = -2.5, Rin = 200
Vin/Vout = -3, Rin = 100
Vin/Vout = 2, Rin = 100
Vin/Vout = 2, Rin = 200
Vin/Vout = 2.5, Rin = 100
Vin/Vout = 2.5, Rin = 200
None of the above
Can you show us how you arrived at your conclusion? We won't confirm a guess...
Hi joey5981. http://img96.imageshack.us/img96/5725/red5e5etimes5e5e45e5e25.gif
So you believe the 300 ohms resistor (and its 100 ohm companion) do nothing here? How can you prove this?
Vin/Vout = -2, ...
The gain was given as this? Or did you mis-type what the book showed as Vout/Vin?
Due to the unequal 200 and 300 ohm resistors this is not a differential amplifier in the accepted sense. In other words, it has a huge common-mode gain.
If you accidentally labeled the 300 ohm resistors so it should have been 200 ohms, then you should come up with a computation as gneill asks for.
