Differentiate -5/3x: "Why is Derivative 5/3x^2?
  • Thread starter Thread starter stat643
    Differentiate
7 replies · 4K views
stat643
i can differentiate most other simple functions.. .though can someone please help me to understand why the derivative of f(x)=-5/3x is simply 5/3x^2?
Do you know the power rule for differentiating functions like [itex]x^n[/itex]? (Hint: [itex]1/x = x^{?}[/itex].)
Its basically following the rule:
[tex]\frac{d}{dx} ax^n = anx^{n-1}[/tex]
where in your example [itex]a=\frac{-5}{3}[/itex] and [itex]n = -1[/itex].
EDIT: puppy interupted hence late reply :-p
1/x = x^-1 and yes i can differentiate functions in the form x^n
Then you should be able to solve this as that's all that's needed.
oh i see , i just didnt realize n was -1, but obviously it is wen its on the denominator, problem solved. cheers
F(x) = [tex]\frac{-5}{3x}[/tex]
The first thing you got to do is re-write the function so we get:
F(x) = [tex]\frac{-5}{3}[/tex] . [tex]\frac{1}{x}[/tex]
F(x) = [tex]\frac{-5}{3}[/tex] . x[tex]^{-1}[/tex]
after re-writing the function, find the most appropriated way to derivate the function in this case it would be: [tex]\frac{d}{dx}[/tex] [u[tex]^{n}[/tex]] = nu[tex]^{n-1}[/tex] u'
Using this rule we get:
F'(x) = (-1) . [tex]\frac{-5}{3}[/tex] . x[tex]^{-2}[/tex] (1) , then simplify
F'(x) = [tex]\frac{5}{3}[/tex] . x[tex]^{-2}[/tex], then re-write
F'(x) = [tex]\frac{5}{3}[/tex] . [tex]\frac{1}{x^{2}}[/tex]
F'(x) = [tex]\frac{-5}{3x^{2}}[/tex]
You don't have to use the power rule for negative powers, you can use the quotient rule: -5/3x= f(x)/g(x) with f(x)= -5 and g(x)= 3x.
(f/g)'= (f'g- fg')(g2)
Since f'= 0 and g'= 3, that gives (-5/3x)'= ((0)(3x)- (-5)(3))/(9x2= 5/3x2.
The reason I mention that is that before you can use the power rule for negative powers you have to prove it for negative powers- and you do that by using the quotient rule:
x-n= 1/xn= f/g with f(x)= 1, g(x)= xn. f'= 0, g'= nxn-1 so (x-n)'= (1/xn)'= ((0)(xn)- 1(nxn-1)/x2n= n xn-1/x2n= n x(n-1)- 2n= n x-n-1.
