Differentiating: Clarifying the Process
4 replies · 2K views · last reply
DiamondV
Differentiate
Equation g(x) = sin(sin(sin(x))), a triple-nested sine function of x.
Handwritten equation u = sin(x).
Handwritten equation: v = sin(u)
Equation g(v) = sin(v)
du/dx = cos(x) dv/du=cos(u) dg/dv=cos(v)
dg/dx = dg/dv.dv/du.du/dx
= cosx.cos(sinx).cos(sin(sinx))
I know the answer is correct but my issue is in the understanding of the solution given. I understand it all except the u = sin(x). The approach I take is to work from the inside to the outside by finding u as the inner most and g(v) as the outermost. What I don't understand is why isn't u = x? isn't that the inner most?
Thanks.
DiamondV said:
Differentiate
Equation g(x) = sin(sin(sin(x))), a triple-nested sine composition.
Short equation written as u = sin(x).
Equation v = sin(u) written as plain text, with the variable u inside the sine function.
Small formula g(v) = sin(v), defining g as the sine function of its input v.
You should never make the substitution u = x, because it's not useful. In that case, all you're doing is changing the name of the variable from x to u. The innermost function of x is sin(x).
Ah. So I should think of it as the innermost FUNCTION of x not just x. So its all about the functions? What if it was x^2 instead of the x? would the innermost function be x^2?
Yes, because this is a function of x, rather than just plain x.
Perfect. Thanks so much!
