Differentiation from first principles
  • Thread starter Thread starter Electrifying
    Differentiation
The discussion revolves around differentiating the function y = √(a² - x²) from first principles. Participants are exploring the concept of differentiation and the application of limits in calculus.
  • The original poster attempts to apply the limit definition of the derivative but struggles with manipulating the resulting expression. Some participants question the variables involved, particularly whether a and b are constants or variables, and clarify the function's form. Others suggest methods for simplifying the expression, such as using the sum of square roots.
Participants are actively engaging with the problem, offering guidance on notation and manipulation techniques. There is a recognition of the need for clarification regarding the variables involved, and some productive suggestions have been made to assist in the differentiation process.
There is a mention of potential confusion due to a typo in the function's expression, which initially led to a misunderstanding of the variables. The discussion also touches on the use of LaTeX for mathematical notation.
Electrifying
Hey guys, I've got the following 2 mark question on a problem sheet, but I can't seem able to do it. I'd appreciate any help, thanks.
Differentiate, from first principles, the following:
[tex]y=\sqrt(a^2-x^2)[/tex]
I know I have to take the limit as δx tends to 0 of [(f(x+δx)- f(x)]/δx but can't seem to manipulate the resultant expression in any way to get closer to an answer. I have never used this Latex thingy before, so hopefully it comes out OK.
Thanks in advance!
[tex]y=\sqrt(a^2-b^2)[/tex]
There is no x in the formula for your function. Are a and b constants or are they variables? If a and b are constants, then the graph of your function is a horizontal line, making the derivative zero.
Sorry, just a typo, [tex]b^2[/tex] should be [tex]x^2[/tex].
But a is just a constant yes.
As for Latex thingies, use curly brackets{} for the argument of the square root.
[tex]y=\sqrt{a^2-x^2}[/tex]
It is a good method to eliminate difference of square roots by multiplying and dividing with the sum of the same square roots.
Write up the the expression (f(x+δx)-f(x))/δx with the square roots and you will see what I mean. ehild
Thank you very much for that, my final answer of
[tex]\frac{dy}{dx} =-\frac{x}{\sqrt{a^2-x^2}}[/tex]
Agrees with the answer obtained if you just differentiate 'normally'. Thanks again!
