Difficulty to find this integral
The integral \(\int \frac{1}{\sqrt{5x+8}}dx\) can be approached using two substitutions: (a) \(u=5x+8\) and (b) \(u=\sqrt{5x+8}\). For (a), the correct transformation leads to \(\int \frac{du}{5\sqrt{u}} = \frac{2\sqrt{u}}{5} + C\), while the initial logarithmic approach was incorrect. In (b), the derivative was miscalculated, leading to confusion about the correct form of \(dx\). The discussion emphasizes the importance of proper substitution and understanding integral forms, correcting several misunderstandings about logarithmic and polynomial integration. Overall, clarity in calculus techniques is essential for solving integrals accurately.
DDarthVader
Hello! I'm doing some calculus exercises and I'm having some difficulty to find the right answer.
The integral is \int \frac{1}{\sqrt{5x+8}}dx and the exercise tell me to solve this by using (a) u=5x+8 and (b) u=\sqrt{5x+8}
This is my attempt:
(a) Well, u=5x+8 then \frac{du}{dx}=5 which means dx=\frac{du}{5}. Then my integral is now \int \frac{du}{5 \sqrt{u}} = \frac{1}{5}ln_{\sqrt{u}} = \frac{1}{5}ln_{\sqrt{5x+8}} = \frac{1}{5}ln_{5x}ln_{8} Is this correct?
(b) Now u=\sqrt{5x+8}. Then \frac{du}{dx}=\frac{1}{2\sqrt{5x+8}} which means dx=2u and now my integral is 2 \int du = u^2 = 5x+8. Is this correct?
Thanks!
(a) ##\int \frac{du}{5 \sqrt{u}}=\frac{1}{5}\int \frac{du}{ \sqrt{u}}=\frac{2\sqrt u}{5}+C##
I get the final result from the general formula (which is very helpful if you remember it): ##\int \frac{f'(x)}{\sqrt{f(x)}}\,dx=2\sqrt{f(x)}+C##
(b) ##\frac{du}{dx}=\frac{1}{2\sqrt{5x+8}}## is wrong.
Oh, I don't know this formula. Thanks!
About the (b), why is it wrong? This is what I did \frac{du}{dx}=\frac{d(\sqrt{5x+8})}{dx}\; \Rightarrow \frac{du}{dx}=((5x+8)^{1/2})' = \frac{1}{2}(5x+8)^{\frac{1}{2}-1}= \frac{1}{2}(5x+8)^{-\frac{1}{2}} = \frac{1}{2}\frac{1}{\sqrt{5x+8}}=\frac{1}{2\sqrt{5x+8}}
This is my attempt:
No. While \int \frac{dx}{x}=\ln(x) you need to keep in mind that the integral only becomes a logarithm when the denominator is a linear equation in x (so of the form ax+b). We don't have that, instead you need to use the rule
\int x^n dx=\frac{x^{n+1}}{n+1} where n=-1/2 in this case.
You forgot about multiplying the expression by the derivative of 5x+8=5.
which means dx=2u
It should be dx=2u\cdot du
Thanks!
\int du= u
\int du= u
Wow! Lots of stupid mistakes. Now I see what I did wrong! Thank you guys very much!
This is my attempt:
Thanks!
NO, NO, NO! Why would you ever think that \ln(5x+8) = \ln(5x) \ln(8)? For that matter, what do you mean by the notation \ln_{\sqrt{u}}? Did you mean to write
\ln \sqrt{u} or \ln(\sqrt{u})?
Anyway, your first approach, giving \frac{1}{5}\ln \sqrt{5x+8} is wrong. The integral
\int \frac{du}{\sqrt{u}} is of the form
\int u^n \, du,
with n \neq -1, so can be integrated without involving logarithms.
Your second approach is wrong: you have the wrong "du".
BTW: to get proper typesetting of math names like log, ln, sin, cos, exp, etc. in LaTeX, you need to enter them as commands, like this: \log, \ln, \sin, \cos, \exp, etc.
RGV
Question: A clock's minute hand has length 4 and its hour hand has length 3. What is the distance between the tips at the moment when it is increasing most rapidly?(Putnam Exam Question) Answer: Making assumption that both the hands moves at constant angular velocities, the answer is ## \sqrt{7} .## But don't you think this assumption is somewhat doubtful and wrong?
  • · Replies 105 ·
  • · Replies 22 ·
