Digital design code converter help
The discussion focuses on designing a code converter to transform decimal digits from the 8-4-2-1 code to Binary-Coded Decimal (BCD). The user attempts to create a mapping between the two codes and constructs Karnaugh maps for simplification but ends up with incorrect results. They seek guidance on their approach and inquire about the conversion methods used for mapping binary to BCD. A question is raised regarding the use of 1's complement in their calculations. The thread highlights the challenges in achieving accurate code conversion and the need for clarification on conversion techniques.
benEE2018
design a code converter that converts a decimal digit from the 8 4 -2 -1 code to BCD.
so i listed out the BCD order from 0 to 9 and listed the weighted 8 4 -2 -1 code so that the weights would equal to the BCD equivalent.
8 4 -2 -1--->BCD
ABCD---> WXYZ
0000---> 0000
0111---> 0001
0110---> 0010
0101---> 0011
0100---> 0100
1011---> 0101
1010---> 0110
1001---> 0111
1000---> 1000
1111----> 1001
I then drew 4 K maps for each variable and arrived at an answer that is completely different from the correct answer, W=AB=AC'D'
the answer i got
Z= A'BD+BCD+AB'D
Y=A'BC'D+ A'BCD'+ AB'C'D+ AB'CD'
X= A'BC'D'+ AB'D+ AB'C
W= AB'C'D'+ AB'CD
i don't know what i am doing wrong and any guidance would be greatly appreciated
What converion method have you used to map binary to BCD?
You seem to have written as 1s complement of the BCD, why?
10K
  • · Replies 19 ·
