Digital Multimeters with a PC interface (recommendations)
Digital multimeters with a PC interface are essential for users seeking to graph data effectively. Recommendations include USB multimeter dongles and specific models from Omega, which are known for their robust PC compatibility. A budget of $250 is suitable for entry-level options that provide decent user interfaces for data visualization. Users should prioritize models that offer seamless integration with PC software for optimal data analysis.
  • Understanding of digital multimeter specifications
  • Familiarity with PC data visualization software
  • Knowledge of USB connectivity standards
  • Basic experience with data logging techniques
  • Research Omega digital multimeters and their PC interface capabilities
  • Explore various USB multimeter dongles and their software compatibility
  • Learn about data visualization tools compatible with multimeter data
  • Investigate user reviews and comparisons of multimeters under $250
Electronics enthusiasts, engineers, and technicians looking to enhance their measurement capabilities with digital multimeters that interface with PCs for data analysis and visualization.
tbader
Any recommendations on multimeters that have a decent PC UI that can graph your data from the multimeter? Budget around $250 which is on the lower end but any recommendations are appreciated.
bumb I need help with this too.
Bump
What have you found so far with Google? Does Omega have anything? Can you just use a USB multimeter dongle?
Both the main electrical cable (three-phase, line to neutral=230V, line to line =400V, 50Hz) and the water supply line(ppr pipe) are underground, below the earth in the garden, located next to each other, the main electrical power has damaged insulation, bare live line is exposed to a water leak from a broken main potable water line. So fault contact happen before RCD. Could this situation be dangerous, especially if a person is showering at the same time? I am trying to understand whether...
  • · Replies 28 ·
