Dimension of \lambda constant in \delta potential
2 replies · 1K views
LagrangeEuler
Time independent Schroedinger equation in ##\delta## potential ##V(x)=-\lambda \delta(x)##, where ##\lambda >0## is given by
[tex]-\frac{\hbar^2}{2m}\frac{d^2}{d x^2}\psi(x)-\lambda \delta(x)\psi(x)=E\psi(x)[/tex].
How to find dimension of ##\lambda##? Dimension of ##V(x)## is
[tex][V(x)]=ML^2T^{-2}[/tex].
Because it is one dimensional problem dimension of ##\psi(x)## is
[tex][\psi(x)]=L^{-\frac{1}{2}}[/tex].
Is then also
[tex][\delta(x)]=L^{-\frac{1}{2}}[/tex]?
The dimension of ##\psi## is irrelevant. From ##\int dx\,\delta(x)=1## it follows that the dimension of ##\delta## is ##L^{-1}##. From that, the dimension of ##\lambda## should be easy.
Reply
Thank you very much.
Reply
