Dimensions of Cosmic Scale Factor ##a(t)##
The discussion centers around the dimensions of the cosmic scale factor ##a(t)## in cosmology, exploring its definition within different metrics and the implications of those definitions. Participants examine the dimensional analysis of the scale factor, its relationship to time and length, and the conventions used in cosmological models.
  • One participant expresses uncertainty about inferring the dimension of ##a(t)## from Hubble's parameter, seeking guidance.
  • Another participant states that the dimension of ##a## depends on its definition in the metric.
  • A participant presents a metric and conducts a dimensional analysis, concluding that ##a(t)## is dimensionless when defined in terms of mass dimensions.
  • Some participants agree that ##a## being dimensionless does not preclude it from being a function of time, using the example of wave frequency.
  • Questions arise regarding the legitimacy of defining length in terms of mass dimensions using the relation ##L=ct##, with mixed responses about its appropriateness.
  • One participant notes that additional choices, such as setting ##G=1##, are necessary to align mass with length and time dimensions.
  • Another participant references an article supporting the conversion of time into length dimensions under certain conditions.
  • A later reply elaborates on two common conventions for the scale factor, one being dimensionless and the other having units of length, with implications for the curvature parameter ##k##.
Participants generally agree that ##a(t)## can be dimensionless, but there is no consensus on the legitimacy of certain definitions and the implications of those definitions on the scale factor's role in cosmology. Multiple competing views regarding the dimensionality and conventions of the scale factor remain present.
Participants express varying assumptions about the definitions of length, time, and mass in their analyses, and there are unresolved questions about the appropriateness of certain dimensional conversions.
AHSAN MUJTABA
TL;DR
I have confusion regarding the dimensions of the cosmic scale factor, ##a(t)##. I have read on the wiki that it is dimensionless, but I wonder about it because it is a function of time, t. I want to use its dimensions to prove the action as non-dimensional.
I know the formula for Hubble's parameter, ##\frac{\dot{a}}{a}##, but I cannot infer any dimension of ##a(t)## from it. Please guide me.
Thanks.
Space news on Phys.org
The dimension of ##a## depends on how you define it in the metric.
Would you please elaborate a little? Thanks.
Just check my work to find dimensions of ##a(t)##.
I have written the metric as,
##ds^{2}=dt^{2}+a(t)^{2}dx^{2}.##
Now, I am aware of the dimensions of the quantities as:
##ds^{2}=[L]^{2}##, ##dt^{2}=[L]^{2}##( I am defining it in terms of length by L=ct, taking c=1.) and ##dx^{2}=[L]^{2}##.
I need to define everything in terms of mass dimensions. I have ##\lambda=\frac{h}{mc}## and working in natural units, I can define the dimension of length in terms of mass as, ##[M]^{-1}.##
Now, the dimensions of time in terms of mass becomes, ##[M]##.
Now, incorporating these dimensions in the metric we get:
##1=1+a(t)^{2},##
##[a(t)]=0.##
So, from this approach, the cosmic scale factor is coming out to be a dimensionless quantity.
Is it a legal approach, please do have a look.
As you have defined it, ##a## is dimensionless, yes. That doesn't stop it being a function of time - for example, if a wave with frequency ##f## passes you then the number of complete cycles that have passed you since time zero is ##ft##. That's both dimensionless and a function of time.
Just one little question, does defining length in terms of mass dimensions by using the relation ##L=ct## is legit or not? In natural units i.e. c=1, the time and length would have the same dimensions.
https://en.wikipedia.org/wiki/Geometrized_unit_system
That seems to me to be defining time in length units or vice versa. You need an additional choice that ##G=1## to get mass in the same units as length and time. I don't usually do it, and I recall Carroll recommending against it. It isn't wrong, though.
According to this article, it is seen that ##L=ct## is right because to convert dimensions of time into length, we set c=1. Secondly, we know Compton's wavelength relation, and from that, we can have ##(mass)^{-1}## dimensions of both time and length.
Yes, now I am clear about that. Thanks.
To elaborate a little bit, there are two common conventions for the scale factor.
One, which usually uses ##a(t)## as its notation, has the scale factor dimensionless and set so that ##a(now) = 1##. With this notation, the curvature parameter ##k## is a real number with units of inverse length squared.
The second one, which usually uses ##R(t)## as its notation, has a scale factor with units of length. In this notation the curvature parameter ##k## is an integer value equal to either -1, 0, or 1, representing whether the universe is negatively-curved, flat, or positively-curved. This scale factor is the radius of curvature of the universe.
Please note the "usually" in the above: just because a source has one or the other doesn't mean that's the notation they're using.
14K
  • · Replies 93 ·
  • · Replies 22 ·
  • · Replies 53 ·
  • · Replies 22 ·
