How Does Internal Resistance Affect Diode Load Line Graphs?
  • Thread starter Thread starter M. next
    Diodes Graphs
The load line graph for a circuit with a diode and no internal resistance exhibits a steeper slope than one with internal resistance, as the latter limits current flow and causes variable voltage drops. In the absence of internal resistance, the diode maintains a constant voltage drop regardless of current. When replacing a DC source with an AC source, the maximum voltage (Vm) cannot be inferred from the DC voltage, as the diode's behavior changes with AC, influenced by frequency and source characteristics. The relationship between voltage and current in AC circuits is not constant like in DC circuits. Understanding these differences is crucial for accurate circuit analysis.
M. next
Hello there,
I have 2 questions:
1)What's the difference between the load line graph of a circuit having (a DC supply, diode with no internal resistance, and a resistor R) & another circuit having (a DC supply, diode WITH internal resistance, and a resistor R)?
2)If we have a circuit supplying the diode with DC voltage, let's say of value (E) - can we conclude from that the Vm (Maximum Voltage) if DC source was replaced by AC one (of the form V=Vmsin(ωt)? Can we? :S
M. next said:
I have 2 questions:
What are your thoughts on this?
Your question is not phrased sufficiently clearly for my understanding.
What's not clear about my second question? What exactly?
And what do you mean by " What are your thoughts on this?"
Exactly the whole question. Can you please re-phrase it in proper english?
1) The load line graph of a circuit with a diode and no internal resistance will have a steeper slope compared to a circuit with a diode and internal resistance. This is because the internal resistance of the diode will limit the current flow and therefore affect the voltage drop across the diode. In the first circuit, the diode will have a constant voltage drop regardless of the current, whereas in the second circuit, the voltage drop will vary with the current due to the internal resistance.
2) No, we cannot conclude the Vm (maximum voltage) of an AC source by knowing the DC voltage applied to the diode. This is because the behavior of a diode changes when an AC source is applied, and it will not have a constant voltage drop like in the DC case. The Vm will depend on the frequency and characteristics of the AC source, and cannot be determined solely by the DC voltage.
Hi all I have some confusion about piezoelectrical sensors combination. If i have three acoustic piezoelectrical sensors (with same receive sensitivity in dB ref V/1uPa) placed at specific distance, these sensors receive acoustic signal from a sound source placed at far field distance (Plane Wave) and from broadside. I receive output of these sensors through individual preamplifiers, add them through hardware like summer circuit adder or in software after digitization and in this way got an...
I have recently moved into a new (rather ancient) house and had a few trips of my Residual Current breaker. I dug out my old Socket tester which tell me the three pins are correct. But then the Red warning light tells me my socket(s) fail the loop test. I never had this before but my last house had an overhead supply with no Earth from the company. The tester said "get this checked" and the man said the (high but not ridiculous) earth resistance was acceptable. I stuck a new copper earth...
I am not an electrical engineering student, but a lowly apprentice electrician. I learn both on the job and also take classes for my apprenticeship. I recently wired my first transformer and I understand that the neutral and ground are bonded together in the transformer or in the service. What I don't understand is, if the neutral is a current carrying conductor, which is then bonded to the ground conductor, why does current only flow back to its source and not on the ground path...
