Dipole moment of polarized sphere
2 replies · 2K views
SallyBieber
Consider a polarised sphere of radius R the polarization is given by
P vector = (ar^2 + b) r hat = ( ar+ b/r) r vector
Where a and b are constant
Find the dipole moment of the sphere
I knew that P (polarized)= delta p / delta volume
So to find dipole moment
I'll take : delta p = [itex]\int p . dv[/itex]
I have a solution manual written in it that
P.r vector = Q
So the delta p = Q/4 pi r^2
How they got this equ.
Should i use the polarized equ. That given
Im so confused
Help
I don't think you need to do any calculation here.
Note that the polarization vector P has a direction that is radially outward at each point of the sphere and the magnitude of P depends only on r.
So, if you consider a small element of volume dV1 at some point in the sphere at a distance r from the center, the dipole moment of that element will be dp1 = P1dV1.
Now consider a second volume element dV2 (same size as dV1) that is at the same distance r from the center but is on the opposite side of the center from dV1. The dipole moment of that element will be dp2 = P2dV2.
How do the magnitudes of dp1 and dp2 compare? How do their directions compare?
What would you get if you add them: dp1 + dp2 = ?
