Can the Direct Sum of Non-Commuting Lie Algebras be Used in L(SO(4))?
deadringer
We are asked to show that L(SO(4)) = L(SU(2)) (+) L(SU(2))
where L is the Lie algebra and (+) is the direct product.
We are given the hint to consider the antisymmetric 4 by 4 matrices where each row and column has a single 1/2 or -1/2 in it.
By doing this we generate four matrices, call them S1, S2, T1, T2
we can show that the commutator of S1, S2 generates another matrix S3 and that the same occurs for the T's. We can show that the 6 matrices form a general basis for L(SO(4))
we then get the following commutation relations:
[Sa, Sb] = epsilon(a,b,c) Sc
[Ta, Tb] = epsilon(a,b,c) Tc
and [Ta, Sb] = 0
We can then see that the S and T matrices form a basis for L(SU(2)) as they obey the correct commutation relations, and therefore the direct sum of these two Lie algebras forms the lie algebra for L(SO(4)).
My question is if we require the two L(SU(2))'s to commute (as they in this case do) in order use their direct sum, or is it okay to take a direct sum of two non-commuting lie algebras. thanks
Let L_1 and L_2 be any Lie algebras. Since L_1 and L_2 are vector spaces, the external vector space direct sum L_1 \oplus L_2 can be formed. The underlying set for the vector space direct sum is
L_1 \times L_2 = \left\{ \left( x,y \right) | x \in L_1, y \in L_2 \right\}.
In order for this set to have vector space structure, scalar multiplication and addition of ordered pairs must be defined. This is done in a natural way:
c \left( x,y \right) := \left( cx,cy \right);
\left( x_1,y_1 \right) + \left( x_2,y_2 \right) := \left( x_1 + x_2,y_1 + y_2 \right).
Now in order to get a Lie algebra, a commutator must be defined on ordered pairs:
\left[\left( x_1,y_1 \right) , \left( x_2,y_2 \right)\right] := \left( \left[x_1,x_2\right] , \left[y_1,y_2\right]\right).
Note that
\left[\left( x , 0 \right) , \left( 0,y \right)\right] = \left( \left[x , 0\right] , \left[0,y\right \right)] = 0.
thanks, I've got it now
How would you show those 6 matrices forma a basis in so(4) ?
Hello everyone, I’m considering a point charge q that oscillates harmonically about the origin along the z-axis, e.g. $$z_{q}(t)= A\sin(wt)$$ In a strongly simplified / quasi-instantaneous approximation I ignore retardation and take the electric field at the position ##r=(x,y,z)## simply to be the “Coulomb field at the charge’s instantaneous position”: $$E(r,t)=\frac{q}{4\pi\varepsilon_{0}}\frac{r-r_{q}(t)}{||r-r_{q}(t)||^{3}}$$ with $$r_{q}(t)=(0,0,z_{q}(t))$$ (I’m aware this isn’t...
Hi, I had an exam and I completely messed up a problem. Especially one part which was necessary for the rest of the problem. Basically, I have a wormhole metric: $$(ds)^2 = -(dt)^2 + (dr)^2 + (r^2 + b^2)( (d\theta)^2 + sin^2 \theta (d\phi)^2 )$$ Where ##b=1## with an orbit only in the equatorial plane. We also know from the question that the orbit must satisfy this relationship: $$\varepsilon = \frac{1}{2} (\frac{dr}{d\tau})^2 + V_{eff}(r)$$ Ultimately, I was tasked to find the initial...
