Direction of an object when the net force is 0
This discussion centers on Newton's First Law of Motion, which states that an object will maintain its state of motion unless acted upon by an external force. Participants clarify that when the net force is zero, an object continues in its original direction at a constant velocity. The conversation highlights the example of an airplane moving at a constant speed, emphasizing that the net force being zero does not imply a lack of motion but rather a lack of change in motion. Additionally, the concept of equilibrium is discussed, particularly in relation to Lagrange points in space.
  • Understanding of Newton's Laws of Motion
  • Familiarity with concepts of force and equilibrium
  • Basic knowledge of momentum in physics
  • Awareness of Lagrange points in celestial mechanics
  • Study the implications of Newton's First Law in various physical scenarios
  • Explore the concept of equilibrium in dynamic systems
  • Research Lagrange points and their significance in orbital mechanics
  • Learn about the relationship between force, mass, and acceleration (Newton's Second Law)
Students of physics, educators teaching Newton's laws, and anyone interested in understanding motion and forces in both terrestrial and celestial contexts.
albert1993
Hello, I'm self studying physics right now and have learned about Newton's laws.
However, I am confused by the first law.
I understand that when the net force is 0, an object will continue its original motion at the same velocity. But how does this work for an airplane which is moving at a constant speed? Since it is going at a constant speed, the net force on the airplane is 0, right? Well, how do we then conclude that the airplane is moving forward, though logically that makes sense?
Newton's laws tell us that as long as the net force on an object is zero, the object will keep moving at a constant speed in a straight line. This applies to an airplane, just like any other object. When the net force on the airplane is zero, it will keep moving in whatever direction it was going. If the plane was moving backward when the net force became zero, it will keep moving backward.
oh yea! there's still time before they all cancel each other out. thanks :D
time?? no. a body in equilibrium (dynamic or static) will ALWAYS remain in equilibrium PROVIDED no external net force acts on the body.
i.e. Total momentum of a system is constant, provided no external net force acts on a system.
i'm sorry.. i don't understand what you mean... but i think i got my question answered..
Your second post implies you didn't understand. What do you think time has to do with the issue?
Consider a spaceship between the Earth and the Moon. There are several points, called Langrange points, where the Earth gravity, Moon gravity, and centripetal forces cancel out. The spaceship is in unstable equilibrium, because any motion away from these points would cause one force to be stronger than the other two. See
http://plus.maths.org/issue36/features/dartnell/index.html
i meant time as, that there was a moment of time that the the net force was not 0 before they all became equal
That isn't necessarily true and certainly isn't relevant. Newton's 1st law doesn't care how two objects got into their current situation, all it does is say that they'll stay in that situation if there is no outside/unbalanced force.
ahh so you're saying that there is no direction of an object when the net force is 0?
The fact that the net force is zero has nothing to do with the direction an object is moving in. It just means that it won't change direction.
kk, so is it impossible to determine the direction of an object when the net force is 0, unless we know what its original direction was (that is if it was moving in the first place), right?
Correct.
Just knowing the net force (even if it's not zero) will not tell you the direction of motion.
Doc Al said:
Correct.
ok, thank you :biggrin:
  • · Replies 33 ·
  • · Replies 49 ·
  • · Replies 54 ·
  • · Replies 33 ·
  • · Replies 17 ·
