What does the direction of angular velocity indicate?
Angular velocity measures the rate of angular displacement around an axis, with its direction defined by the right-hand rule. When the axis is held with the right hand and fingers follow the motion of the rotating body, the thumb indicates the angular velocity's direction. This direction can be above or below the plane, which signifies clockwise or counter-clockwise rotation. Unlike linear velocity, where direction aligns with motion, angular velocity can differ, highlighting its vector nature. Understanding angular velocity is essential for analyzing rotational dynamics, as it reveals the axis of rotation and the speed of rotation.
navneet9431
Angular velocity is the rate of angular displacement about an axis. Its direction is determined by right hand rule.
According to right hand rule, if you hold the axis with your right hand and rotate the fingers in the direction of motion of the rotating body then thumb will point the direction of the angular velocity.
The direction of angular velocity is above or below the plane. But what does it mean? I mean in linear velocity the direction of velocity is in the direction of motion of body but what does it mean that body is moving in one direction while the direction of its angular velocity is in another direction?
It means that angular velocity has a real vector nature. Look at the motion of a gyroscope. If everything were linear, the gyroscope would fall.
It identifies the direction of the axis of rotation. Above or below the plane identifies clockwise or counter-clockwise. The magnitude indicates how fast it is rotating.
It happens to turn out that a three dimensional rotation rate has three degrees of freedom (pitch and yaw of the axis plus roll rate about the axis) just like a three dimensional position vector. It is convenient to represent it as such.
For simple comparison, I think the same thought process can be followed as a block slides down a hill, - for block down hill, simple starting PE of mgh to final max KE 0.5mv^2 - comparing PE1 to max KE2 would result in finding the work friction did through the process. efficiency is just 100*KE2/PE1. If a mousetrap car travels along a flat surface, a starting PE of 0.5 k th^2 can be measured and maximum velocity of the car can also be measured. If energy efficiency is defined by...
  • · Replies 20 ·
