Direction of magnetic force between moving particles
Electrons can exhibit both attractive and repulsive forces depending on their relative motion, with the magnetic force playing a crucial role. The discussion emphasizes that the magnetic force is typically repulsive, and attraction may only occur if an electron travels faster than the speed of light, potentially behaving like a positron. An analogy with parallel currents illustrates how the motion of electrons can lead to perceived attraction due to relativistic effects. Special relativity introduces complexities, such as length contraction, which affects how charges interact in motion. The conversation also touches on the implications of superluminal travel and its relation to time, suggesting that faster-than-light particles could imply backward time travel, though this remains a contentious topic.
[Split off from this thread]
blue_leaf77 said:
Electrons can attract or repel each other when they are in a relative motion, but this is due to the magnetic force.
I think that the force is always repulsive. I think that an electron would have to travel faster than c for it to become attractive.
Whether it is repulsive or attractive depends on whether the two charges are moving in the same or opposite direction. I made analogy with currents running on parallel, neihgboring wires though. I think the same effect can be observed for individual electrons.
I believe that is correct. There is also an intrinsic dipole, but I don't think this changes the conclusion.
Can you give more explanation to your answer?
That effect is due to special relativity. Due to length contraction the electrons in one wire see more protons and fewer electrons in the other wire, hence an attraction between the wires. No protons, no attraction.
An electron moving faster than light would appear to be a positron, which would appear to attract an electron. Richard Feynman thought that this actually was what a positron was.
The electric force is repulsive. The magnetic force may be attractive. The only way for the net force to be attractive is for the magnetic force to be greater than the electric force. I believe that only happens if v>c.
I am familiar with your idea about the wire, I have not met the idea of an ekectron moving faster than the speed of light being a positron
I know of Feynman's view, I think he saw positrons as electrons traveling back in time, shown my the arrow on the positron lines in his diagrams
lychette said:
I am familiar with your idea about the wire, I have not met the idea of an ekectron moving faster than the speed of light being a positronI know of Feynman's view, I think he saw positrons as electrons traveling back in time, shown my the arrow on the positron lines in his diagrams
If someone fires a bullet at you that travels faster than light. The bullet hits you, then you see the bullet flying through the air and be swallowed by the gun. So the bullet appears to be going backward in time.
If an FLT electron in a magnetic field hits you, you then see it returning to its source curving as though it were positively charged.
"The causality problems with superluminal travel come about as follows. Special relativity is based on the axiom that all observers have the same laws of physics, and these are converted from one observer to another by a well-defined procedure called Lorentz-transformation. This transformation from one observer to the other maintains lightcones, because the speed of light doesn’t change. The locations of objects relative to an observer can change when the observer changes velocity. But two observers at the same location with different velocities who look at an object inside the lightcone will agree on whether it is in the past or in the the future.
Not so however with objects outside the lightcone. For these, what is in the future for one observer can be in the past of another observer. This means then that a particle that for one observer moves faster than light – ie to a point outside the lightcone – actually moves backwards in time for another observer! And since in special relativity all observers have equal rights, neither of them is wrong. So once you accept superluminal travel, you are forced to also accept travel back in time.
At least that’s what the popular science books said. It’s nonsense of course because what does it mean for a particle to move backwards in time anyway? Nothing really. If you’d see a particle move faster than light to the left, you could as well say it moved backwards in time to the right. The particle doesn’t move in any particular direction on a curve in space-time because the particles’ curves have no orientation. Superluminal particle travel is logically perfectly possible as long as it leads to a consistent story that unfolds in time, and there is nothing preventing such a story. "---Sabine Hossenfelder http://backreaction.blogspot.com/se...0-04:00&max-results=20&start=27&by-date=false
