Discovering Valid Solutions for Max/Min Values of a Trigonometric Function
  • Thread starter Thread starter Mentallic
The discussion revolves around finding the maximum value of the function \(\sqrt{3}\cos x + \sin x\), which involves trigonometric identities and calculus concepts such as derivatives and critical points.
  • Participants explore different methods to find the maximum value, including the use of derivatives and trigonometric identities. Some question the validity of squaring both sides of an equation and discuss the implications of introducing extraneous solutions. Others suggest alternative approaches using trigonometric identities to simplify the expression.
The discussion is active, with participants sharing various insights and methods. Some have provided alternative perspectives on solving the problem, while others have raised questions about the assumptions made during the process. There is no explicit consensus, but several productive directions have been identified.
Participants note the importance of testing critical points in the original function to avoid extraneous solutions. There is also mention of the periodic nature of trigonometric functions and how it affects the solutions found.
Mentallic
Homework Helper
Note: This problem is no longer a homework question.
I'm asked to find the max value of \sqrt{3}cosx+sinx
y=sinx,y'=cosx
y=cosx, y'=-sinx
cos^2x=1-sin^2x
I let y=\sqrt{3}cosx+sinx
Hence, \frac{dy}{dx}=-\sqrt{3}sinx+cosx=0
Attempting to solve this for x: \sqrt{3}sinx=cosx \Rightarrow 3sin^2x=1-sin^2x
Finally, sinx=\pm\frac{1}{2} \Rightarrow x=\pi n\pm \frac{\pi}{6} , n integral
I tested these values on a graphing calculator for 0\leq x\leq 2\pi because I didn't believe that there should be 4 max/min values, but only 2-3. I found that \pi/6 and 7\pi/6 were max/min values but 5\pi/6 and 11\pi/6 were rather just random points on the function and its derivative.
So I'm guessing that I found extra wrong values when I squared both sides of the derivative? Is it possible to square the equation, but quickly find which values in the results aren't valid and need to be scrapped? After solving the equation this way, I realized that the values that are valid are located in the first and third quadrants which are both positive for the tangent function and thus I could've divided the derivative through by cosx.
This doesn't answer your question, but I find it to be another nice way of solving the problem.
Notice that \sqrt{3}^2+1^2=2^2.
So If you divide both sides of the equation by 2, you get:
\frac{y}{2}=\frac{\sqrt{3}}{2}}\cos(x)+\frac{1}{2}\sin(x)=\sin(\pi/3)\cos(x)+\cos(\pi/3)\sin(x)=\sin(x+\pi/3).
So y=2\sin(x+\pi/3), whose maximum value is 2.
It can be shown similarly that if y=A\cos(x)+B\sin(y), then the maximum is just \sqrt{A^2+B^2}.
When you square both sides of an equation, as you do here, you may introduce new solution that do not satisfy your original equation. For an obvious example, x= 2 has the single solution 2 but x2= 4 has both 2 and -2 as solutions.
The simplest way to distinguish "extraneous solutions" is to try them in the original equations.
But I don't see any reason to square both sides: there is no square root of the unknown and \sqrt{3} is just a number. From -\sqrt{3}sin(x)+ cos(x)= 0, \sqrt{3}sin(x)= cos(x) so
\frac{sin(x)}{cos(x)}= \frac{1}{\sqrt{3}}
which leads to \pi/6, as a "fundamental solution" and, since tan(x) is periodic with period \pi, x= \pi/6+ n\pi as general solution, no "-".
I cannot figure out what the significance of \sqrt{3}^2+1^2=2^2
Also, I already deduced before posting that \sqrt{3}cosx+sinx=2cos(x-\frac{\pi}{6} but you have showed me another way of finding that. thanks :smile:
which leads to \pi/6 as a "fundamental solution" and, since tan(x) is periodic with period \pi, x= \pi/6+ n\pi as general solution, no "-".
I'll test in the original function in future then. I didn't realize this, thanks! It's way simpler to solve this way.
Furthermore, knowing where the critical points lie, we may use the second derivative to find out which of those x's are maxima:
f''(x)=-\sqrt{3}\cos(x)-\sin(x)=-\cos(x)(\sqrt{3}+\frac{\sin(x)}{\cos(x)})
At the critical points, we get here the value:
-\cos(x)(\sqrt{3}+\frac{1}{\sqrt{3}}), which shows that the maxima will occur for critical x's lying in the first quadrant, never in the fourth.
You want to divide both sides of the equation by some C such that \sin(\alpha)=\sqrt{3}/C and \cos(\alpha)=1/C. (So that we can use the trig summation identity)
Then it must be true that (\sqrt{3}/C)^2+(1/C)^2=1. It follows that C^2=3+1.
So in general, for y=A\cos(x)+B\sin(y), you want to divide by \sqrt{A^2+B^2}. Then you can write y=\sqrt{A^2+B^2} \cdot \sin(\alpha+x).
Sorry for hijacking the thread. Just wanted to share a neat trick that could come in handy in other places. :-p
The signicance is that its positive square root, 2, is the answer to your original question!
Your problem did not ask for the value of x that gives that.
Alligatorman's point is that, sin(x+ y)= cos(x)sin(y)+ sin(x)cos(y) so if you have something of the form Acos(x)+ Bsin(x), you can look for a "y" such that sin(y)= A, cos(y)= B. Of course, because sin^2(y)+ cos^2(y)= 1, that is only possible if A^2+ B^2= 1. If not, as in this case where A= \sqrt{3} and B= 1, we must multiply and divide by \sqrt{A^2+ B^2}. Here, of course, A^2+ B^2= 3+1= 4 so \sqrt{A^2+ B^2}= 2. If we multiply and divide by 2, we have
2\left(\frac{\sqrt{3}}{2}cos(x)+ \frac{1}{2}sin(x)\right).
There does exist y such that sin(x)= \sqrt{y}/2 and cos(y)= 1/2. It easy to see that y= \pi/6 satisfies that but we don't need to: this is of the form 2 sin(x+y) which we know has a maximum value of 2 because sine itself has a maximum value of 1.
Ahh thanks for all your help everyone!
Alligatorman, I appreciate your attempts but without Hallsofivy's response I still wouldn't have understood it clearly. But don't worry, that's just due to my feable abilities to understand simple math :smile:
