Dispersion relation for diatomic linear chain.
The discussion centers on the dispersion relation for a diatomic linear chain, specifically addressing the behavior when both atoms are set to equal mass (m_1 = m_2 = m). The key issue raised is the persistence of the optical mode term (ω_+) in the dispersion relation, which complicates the reduction to the acoustic mode. The derived equations show that both modes exist due to the two-atom basis, and the confusion arises from the interpretation of the lattice structure. The conversation concludes that the presence of two modes is valid and relates to the choice of reduced versus extended zone schemes.
  • Understanding of phonon dispersion relations
  • Familiarity with diatomic linear chains in solid-state physics
  • Knowledge of trigonometric equations
  • Concept of reduced and extended zone schemes
  • Study the derivation of phonon dispersion relations in diatomic lattices
  • Explore the implications of reduced and extended zone schemes in solid-state physics
  • Investigate the physical significance of acoustic and optical modes in crystal structures
  • Learn about the mathematical treatment of lattice vibrations and their modes
Physicists, materials scientists, and students studying solid-state physics, particularly those interested in lattice dynamics and phonon behavior in crystal structures.
Wminus
Hi. Here's the dispersion relation for a diatomic linear chain, where the distance is a/2 between each atom.
My issue here is that if you set m_1=m_2=m, i.e. set both atoms equal to each other, it doesn't automatically reduce to the old acoustic dispersion relation as the ± term doesn't disappear.
What's up with that?
I can't see any problem. Maybe you should fresh up your knowledge of the trigonometric equations?
OK, sorry I should've written everything out in details in the OP. My problem is that the plus-minus sign is being problematic. It gives two solutions that are phase-shifted with regards to each other. Setting the masses equal, the equation from OP reduces to:
##\omega^2 = K(2/m) \pm K \sqrt{(2/m)^2 - (2/m)^2 sin^2{ka/2}} = \frac{2K}{m}(1 \pm cos(ka/2)) \Rightarrow \omega_+ = \sqrt{\frac{4K}{m}} |cos(ka/4)|## & ## \omega_- = \sqrt{\frac{4K}{m}} |sin(ka/4)|##.
How do I get rid of the ##\omega_+## term, the optical mode? Which physical argument makes it invalid?
They are both correct. Note that your basis contains two atoms and not just one, so that a is different.
If you graph both of them in a diagram, you get a dispersion relation with 2 modes! This is supposed to be impossible, isn't it?
No, it isn't. You have a basis with two atoms, so you get two modes, an acoustic one and an optical one. However, when the two atoms become identical, the two curves will touch at the zone boundaries.
Do you know the difference between a reduced and an extended zone scheme? Here it is for the example of a quasi-free electron:
http://www.pha.jhu.edu/~jeffwass/2ndYrSem/pics/Slide19.JPG
I think I do, yes. But in the case of a single-atom chain there should be only one mode regardless of what basis or zone scheme you choose. Right?
I mean, the two-atom chain with masses m_1 and m_2 should turn into a standard single-atom chain if we set m_1=m_2=m. So the dispersion relation should go from just one mode to two, right?
It doesn't because you chose to describe it using a lattice with a cell containing two atoms instead of one. Given N atoms for a whole crystal, you can describe it in terms of either N k-values forming one band or N/2 k-values forming two bands.
I think I get all of this now. It's got to do with the reduced/extended scheme ways of viewing the dispersion relation. thanks.
  • · Replies 30 ·
